Hmg4 tree class
l3whmg
Hmg4 tree class
Post by l3whmg »
Hi friends.
I modified the source code of the TREE class.
In order to test this version, you must:
  • 1) make a copy of the "source/tree.prg" file
    2) unzip the contents of the TREE.ZIP within the source folder
    3) unzip the contents of the TREENEWDEMO.ZIP within samples folder
    4) compile HMG4 lib
    5) build demo programs within treeNEWDEMO
Attention:
A) all other demo programs, with use of the TREE class, can't work. THIS is a class demo version
B) when you have completed your tests, you must: restore previous source/tree.prg and remove samples/treeNEWDEMO folder
Beware: the old ITEMIDS system is not implemented yet
I'm waiting your opinion.
Best regards
tree.zip
(4.74 KiB) Downloaded 286 times
treeNEWDEMO.zip
(22.62 KiB) Downloaded 285 times
Luigi from Italy
www.L3W.it
Ricci
Re: Hmg4 tree class
Post by Ricci »
I implemented it into my program. Works great, only one error:
Line 548 (METHOD Value( nArg1 ) CLASS TREE) should be " oQtWidget := ::aTreeItems[nArg1,1]"
l3whmg
Re: Hmg4 tree class
Post by l3whmg »
Hi Ricci, many thanks. I will do the change.
Cheers
Luigi from Italy
www.L3W.it
