Error within BASIC class, New() method
concentra
Post by concentra »
In the following code:
FUNCTION Main()
   LOCAL oWindow
   LOCAL oToolBar
   LOCAL oButton1
   HbQt_ErrorSys()
   WITH OBJECT oWindow := Window():New()
      WITH OBJECT oToolBar := ToolBar():New()
         WITH OBJECT oButton1 := ToolButton():New("oButton1")
            :Caption   := 'Call dialog'
            :OnClick   := { || CallDialog() }
         END WITH
      END WITH
   END WITH
   oWindow:Activate()
STATIC FUNCTION CallDialog()
   LOCAL oDlg
   LOCAL oButtonBox
   WITH OBJECT oDlg := Dialog():New( "oDlg" )
      :Width   := 200
      :Center()
      WITH OBJECT oButtonBox  := ButtonBox():New("oButtonBox")
         :addButton( BUTTON_OK    ,, { || oDlg:Accept() } )
         :addButton( BUTTON_CANCEL,, { || oDlg:Reject() } )
      END WITH
   END WITH
   oDlg:Activate()
If the button that calls the dialog is clicked more than one time I get an error:
error within BASIC class, New() method
And I was unable to find why...
[[]] Mauricio Ventura Faria
mrduck
Re: Error within BASIC class, New() method
Post by mrduck »
The problem reported is a serious one...
you can temporary solve with
concentra wrote: WITH OBJECT oDlg := Dialog():New( )
but the underlying problem is more serious...
concentra
Post by concentra »
Francesco, I don't know if it's related but if the buttonbox is removed, another error rises, related to eventloop, when the dialog is closed.
mrduck
Post by mrduck »
concentra wrote:Francesco, I don't know if it's related but if the buttonbox is removed, another error rises, related to eventloop, when the dialog is closed.
Please, a code snippet... I've never used dialog.... ( I think to know what this problem is, but I need a piece of code to test)
concentra
Post by concentra »
mrduck wrote:Please, a code snippet... I've never used dialog.... ( I think to know what this problem is, but I need a piece of code to test)
The very same, without the buttonbox:
FUNCTION Main()
   LOCAL oWindow
   LOCAL oToolBar
   LOCAL oButton1
   HbQt_ErrorSys()
         END WITH
      END WITH
   END WITH
   oWindow:Activate()
   LOCAL oDlg
   LOCAL oButtonBox
      :Width   := 200
      :Center()
//      WITH OBJECT oButtonBox  := ButtonBox():New("oButtonBox")
//         :addButton( BUTTON_OK    ,, { || oDlg:Accept() } )
//         :addButton( BUTTON_CANCEL,, { || oDlg:Reject() } )
//      END WITH
   END WITH
   oDlg:Activate()
mrduck
Post by mrduck »
With or without that lines the problem stays.... I understand it, I will fix later.
concentra
Post by concentra »
Another question...
Is keyboard navigation disabled by default in grids ?
I can't navigate using keyboard, only with mouse...
#include "hbqtgui.ch"
FUNCTION Main()
   LOCAL oWindow
   LOCAL oGrid
   LOCAL I
   LOCAL aStru := { { "FIELD1", "C", 12, 0 },;
                    { "FIELD2", "C", 12, 0 },;
                    { "FIELD3", "C", 12, 0 } }
   HbQt_ErrorSys()
   DBCREATE( "TESTE", aStru )
   USE TESTE
   FOR I := 1 TO 100
      DBAPPEND()
      TESTE->FIELD1 := "1111"
      TESTE->FIELD2 := "2222"
      TESTE->FIELD3 := "3333"
   GO TOP
      :Width   := 780
      :Height  := 500
      WITH OBJECT oGrid := VirtualGrid():New("oGrid")
         :Width     := 770
         :Height    := 490
         :WorkArea  := 'TESTE'
      END WITH
   END WITH
   oWindow:Activate()
Nope. Keyboard navigation is not disabled by default.
However, cellnavigation is disabled by default in HMG3.
concentra
Post by concentra »
rathinagiri wrote:Nope. Keyboard navigation is not disabled by default.
It's related to Harbour build.
I returned a previous 3.1 Harbour version and the navigation is ok again.
mrduck
Post by mrduck »
Mauricio,
I have a set of commits to make, one solves this problem. DoKeyboardEvent in a point returns .T., change to .F.
An event that returns .T. stops the "event train", it means Qt doesn't handle the event... with .F. Qt handles the event...
In HMG4 Changelog this is described
