Widget Style
pctoledo
Widget Style
Post by pctoledo »
Hi Friends, Qt's support for widget styles and themes enables your application to fit in with the native desktop enviroment. I modified the file hmgapp.prg to set the styles:
File: globshared.prg
   CLASS VAR s_cStyle                  INIT  NIL      SHARED
File: hmgapp.prg
   METHOD Style                        SETGET
METHOD Style( cStyle ) CLASS HMGAPP
   IF PCOUNT() == 0
      RETURN ::s_cStyle
   ELSEIF ::s_lQtStarted == .F. .AND.  hb_IsChar( cStyle ) == .T.
      ::s_cStyle := cStyle
RETURN Self
METHOD Reset() CLASS HMGAPP
   ::s_oQtApp           := NIL
   ::s_oQtRes           := NIL
   ::s_aResources       := {}
   ::s_oDefaultParent   := NIL
   ::s_nObjectCounter   := 0
   ::s_oMainWindow      := NIL
   ::s_lGridCellFlag    := .F.
   ::s_oMainMenu        := NIL
   ::s_oParentWindow    := NIL
   ::s_cNewPopUpMenuName:= NIL
   ::s_cNewMenuItemName := NIL
   ::s_nCountry         := NIL
   ::s_oCurWindow       := NIL
   ::s_nLanguage        := NIL
   ::s_bOnShutDown      := NIL
   ::s_bOnStartUp       := NIL
   ::s_cPlugInDir       := NIL
   ::s_oQtLocale        := NIL
   ::s_lQtStarted       := .F.
   ::s_oTopParent       := NIL
   ::s_cStyle           := NIL
RETURN Self
METHOD Start() CLASS HMGAPP
   LOCAL cPath, cFile, cExt, nX, cResFileName
   // check if it's already started
   IF ::s_lQtStarted == .T.
      RETURN Self
   // split program name for two reason
   // 1. to have the current path
   // 2. to have the program name and register default resource with program name
   hb_fNameSplit( hb_ProgName(), @cPath, @cFile, @cExt )
   ::s_lQtStarted := .T.
   ::s_oQtApp     := QApplication()
   ::s_oQtRes     := QResource()
   // localization
   IF VALTYPE( ::s_nLanguage ) == "U"
      ::s_oQtLocale     := QLocale()
      ::s_oQtLocale:setDefault( QLocale() )
   ELSEIF VALTYPE( ::s_nLanguage ) == "N"
      IF VALTYPE( ::s_nCountry ) == "U" ; ::s_nCountry := 0 ; ENDIF     // 0 is like QLocale_AnyCountry
      ::s_oQtLocale     := QLocale( ::s_nLanguage, ::s_nCountry )
      ::s_oQtLocale:setDefault( QLocale( ::s_nLanguage, ::s_nCountry ) )
   // if ::s_cPlugInDir not evaluated create a default <exePath\Qt\plugins>. If qt.conf exists take that
   IF VALTYPE( ::s_cPlugInDir ) == "U"
      ::s_cPlugInDir := cPath + "Qt" + hb_ps() + "plugins"
   ::s_oQtApp:addLibraryPath( ::s_cPlugInDir )
   ::s_oDefaultParent   := Self
   ::s_oTopParent       := Self
   ::oQtObject          := ::s_oQtApp:DeskTop()
   // by default register resource file with the same name of program (see harbour)
   Self:RegisterResource( cFile )
   FOR nX := 1 TO LEN( ::s_aResources )
      cResFileName := ::s_aResources[nX]
      IF TYPE( cResFileName ) == "UI"  // to find if exist this function
         ::s_oQtRes:registerResource_1( &cResFileName )
   NEXT nX
   // Set Widget Style
   IF VALTYPE( ::s_cStyle ) == "C"
      ::s_oQtApp:SetStyle( ::s_cStyle )
   //    check OnStartUp
   IF hb_IsBlock( ::s_bOnStartUp ) == .T.
      EVAL( ::s_bOnStartUp )
RETURN Self
Example use:
FUNCTION Main
   LOCAL oWindow
   HbQt_ErrorSys()
   HMGAPP():Style( "cleanlooks" )
   WITH OBJECT oWindow := Window():New()
      :Row      := 10
      :Col      := 10
      :Width    := 400
      :Height   := 400
      :Title    := 'Widget Styles'
      :Type     := WND_MAIN
      :OnInit   := { || oWindow:Center() }
   END WITH
   oWindow:Activate()
Supported styles:
cleanlooks
plastique
motif
CDE
windows
windowsxp
windowsvista
macintosh
GTK
Sample:
style.zip
File Samples
(3.54 KiB) Downloaded 256 times
Toledo
Clipper On Line
Re: Widget Style
This is so nice.
l3whmg
Re: Widget Style
Post by l3whmg »
Many thanks. Very nice.
Luigi from Italy
www.L3W.it
mrduck
Re: Widget Style
Post by mrduck »
pctoledo wrote:Hi Friends, Qt's support for widget styles and themes enables your application to fit in with the native desktop enviroment.
Patch committed to svn, please check
pctoledo
Re: Widget Style
Post by pctoledo »
mrduck, all ok!
Thanks for the help.
Toledo
Clipper On Line
