About hmg3 and hmg4 compatibility
mrduck
Post by mrduck »
One of the goal of hmg4 project is to allow hmg3 code to be easily ported to hmg4. This was repeteaded several times.
My first attempt to port a component not yet ported from hmg3 to 4 was (and actually is since it is far to be completed) a nightmare. But it was an internal component and so I thought is was normal that it would take a lot of effort.
Now I decided to port a sample project, found in hmg3 samples\agenda, since it uses a CHILD window and I wanted to check how this window behaves.
First compilation reports 17 errors.... I 'm just starting to see what these errors are about and what changes needs to be done to the code, if something is still missing in hmg4 or broken.... let's see what should be changed....
does anybody more proficient than me on hmg3 wants to join me on this exercise ?
Francesco
Agenda.prg(86) Error E0030  Syntax error "syntax error at 'ITEM'"
Agenda.prg(89) Error E0030  Syntax error "syntax error at 'CONTROL'"
Agenda.prg(93) Error E0030  Syntax error "syntax error at 'WINDOW'"
Agenda.prg(107) Error E0030  Syntax error "syntax error at 'ITEM'"
Agenda.prg(110) Error E0030  Syntax error "syntax error at 'ITEM'"
Agenda.prg(142) Error E0030  Syntax error "syntax error at 'WINDOW'"
Agenda.prg(366) Error E0030  Syntax error "syntax error at 'WINDOW'"
Agenda.prg(377) Error E0020  Incomplete statement or unbalanced delimiters
Agenda.prg(401) Error E0030  Syntax error "syntax error at 'WINDOW'"
Agenda.prg(421) Error E0020  Incomplete statement or unbalanced delimiters
Agenda.prg(431) Error E0020  Incomplete statement or unbalanced delimiters
Agenda.prg(447) Error E0020  Incomplete statement or unbalanced delimiters
Agenda.prg(513) Error E0030  Syntax error "syntax error at 'CONTROL'"
Agenda.prg(516) Error E0020  Incomplete statement or unbalanced delimiters
Agenda.prg(601) Error E0030  Syntax error "syntax error at 'CONTROL'"
Agenda.prg(603) Error E0030  Syntax error "syntax error at 'WINDOW'"
Agenda.prg(614) Error E0030  Syntax error "syntax error at 'CONTROL'"
17 errors
mrduck
Re: About hmg3 and hmg4 compatibility
Post by mrduck »
NOTE: the source code is in a state that it is impossible to compile and of course run, so what I'm reporting here are PROPOSALs that must be checked when the source code will finally compile and run.
Ok, some of the errors are from a missing #translate:
CENTER WINDOW Form_3
Probably it was missing due to the previous way of objects defining (objects created later) but now I think it is possible to translate it to
Form_3:center()
because Form_3 and it's underlying Qt object is created at the DEFINE.
down to 14 errors with no changes at the code
Compiling 'Agenda.prg'...
14 errors
mrduck
Post by mrduck »
Another class of problems....
look at this code
If Empty( Form_2.T_Nome.Value )
  MsgINFO( "Nome não foi Informado!!" , "Agenda" )
  Form_2.T_Nome.SetFocus
EndIf
hmg4 preprocessor translates to
If Empty( Form_2:T_Nome:Value )
  Form_2:T_Nome:SetFocus
EndIf
At compile time the compiler reports an error on :SetFocus... the :Value should be ok since it is a SETGET method.... should we transform SetFocus to a SETGET method ? Or go the preprocessor route ? Both won't work. The SETGET since we don't have the assignment part (the := <value> part) the second... well, I was not able to change Form_2:T_Nome:SetFocus to Form_2:T_Nome:SetFocus() in the preprocessor without creating a circular reference and breaking the compile...
So I now manually change SetFocus to SetFocus()... if anyone has an idea is welcome...
agenda.prg(86) Error E0030  Syntax error "syntax error at 'ITEM'"
agenda.prg(89) Error E0030  Syntax error "syntax error at 'CONTROL'"
agenda.prg(107) Error E0030  Syntax error "syntax error at 'ITEM'"
agenda.prg(110) Error E0030  Syntax error "syntax error at 'ITEM'"
agenda.prg(142) Error E0030  Syntax error "syntax error at 'WINDOW'"
agenda.prg(401) Error E0030  Syntax error "syntax error at 'WINDOW'"
agenda.prg(421) Error E0020  Incomplete statement or unbalanced delimiters
agenda.prg(431) Error E0020  Incomplete statement or unbalanced delimiters
agenda.prg(513) Error E0030  Syntax error "syntax error at 'CONTROL'"
agenda.prg(601) Error E0030  Syntax error "syntax error at 'CONTROL'"
agenda.prg(614) Error E0030  Syntax error "syntax error at 'CONTROL'"
11 errors
mrduck
Post by mrduck »
Do with <w>.Release what already done with .SetFocus
There are also some ACTION/codeblocks with .SetFocus and I changed them as well since they will probably create error at runtime.
down to 9 errors
9 errors
mrduck
Post by mrduck »
There are some commands of the type:
MODIFY CONTROL Edit_1 OF Form_3 FONTSIZE nFont
in hmg3 is
#translate MODIFY [ PROPERTY ] [ CONTROL ] <Arg2> OF <Arg1> <Arg3> <Arg4> ;
SetProperty ( <"Arg1"> , <"Arg2"> , <"Arg3"> , <Arg4> )
(set/getProperty... mmm....)
Let's see if we can transform in:
Form_2:Edit_1:fontsize := nFont
This translate takes care of it:
<Arg1>:<Arg2>:<Arg3> := <Arg4>
in hmg3 i_controlmisc.ch there are some other combinations of this translate so we should also port them....
down to 5 errors
5 errors
mrduck
Post by mrduck »
RELEASE WINDOW ALL is the correct way to close application in hmg3. I just translate it to QUIT
#command RELEASE WINDOW ALL  ;
   quit
down to 3 errors...
mrduck
Post by mrduck »
command like
ADD ITEM { CHR(i+64) } TO GIndice OF Form_1
added
#command ADD ITEM <i> TO <n> OF <p> ;
   <p>:<n>:addItem( <i> )
down to 1 error
mrduck
Post by mrduck »
Last command to be converted:
DELETE ITEM ALL FROM Grid_Agenda OF Form_1
In hmg3
#command DELETE ITEM ALL FROM <n> OF <p>;
   DoMethod ( <"p"> , <"n"> , 'DeleteAllItems' )
In hmg4
#command DELETE ITEM ALL FROM <n> OF <p> ;
   <p>:<n>:deleteAllItems( )
now we have 0 compile errors... but one link error:
undefined reference to `HB_FUN_GETCONTROLTYPE'
mrduck
Post by mrduck »
GetControlType in hmg3 is a function and it is ok in the hmg3 semi-oop style...
Function GetControlType (ControlName,ParentForm)
Done that, now is the line
   aRet := GetProperty (  ParentForm  , ControlName , 'Item' , GetProperty( ParentForm , ControlName , 'Value' ) )
that doesn't work since hmg4 implementation has only 3 parameters.... I'm trying to understand what this line wants to get... do you how to translate it in hmg4 ?
I am sure you have done a wonderful work here Francesco. I have tried one of my projects and could get it compiled with minimal changes.
I use standard calls to HMG and use MainWindow and several ModalWindows only. No other window types. I will post the project here.
