Just upgraded to 3.0.38, but have problem...
James
Post by James »
Hello, everybody, how are you? I'm fine. I just get this message when I push Play in HMG.
Am I the only one with this problem?
Re: Just upgraded to 3.0.38, but have problem...
Sorry, it is my mistake. :(
Please delete hmg.ini in ide folder.
James
Post by James »
Thanks, Rathinagiri! :)
James
Post by James »
Hi, everybody, thanks for your help, I'm having another challenge with newly installed 3.0.38:
When I click here, nothing happens.
Also, I opened the SAMPLE\CONSOLE program, and it won't work, and I can't find the console setting:
Thanks for your help. :)
tave2009
Post by tave2009 »
Hello everyone.
I installed: HMG 3.0.38 from 0, and I have the same problem. I saw a post where you change the "build.bat", but does not fix the problem.
regard
Walter
Sorry, I will check and solve the problem. :(
I've installed hmg.3.0.38 to my hmg 3.0.36 folder and everything seems to be OK.
I've rebuild my huge billing project, all test gone excellent till now.
Compilation time is longer than harbour 2.0 :(
Something is wrong with reports, I suppose.
I think this problem is caused by missing library hbvpdf, which is placed in harbour\lib, but not included in linking process via IDE
While compiling one of my projests, where REPORT is used, I get an error:
Harbour 3.0.0 (Rev. 16951)
Copyright (c) 1999-2011, http://harbour-project.org/
c:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x1a8): undefined reference to `HB_FUN_PDFINIT'
c:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x1c8): undefined reference to `HB_FUN_PDFOPEN'
c:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x2f8): undefined reference to `HB_FUN_PDFNEWPAGE'
c:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x3a8): undefined reference to `HB_FUN_PDFCLOSE'
c:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x478): undefined reference to `HB_FUN_PDFSETFONT'
c:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x488): undefined reference to `HB_FUN_PDFATSAY'
c:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x498): undefined reference to `HB_FUN_PDFTEXTWIDTH'
c:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x4c8): undefined reference to `HB_FUN_PDFIMAGE'
c:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x4e8): undefined reference to `HB_FUN_PDFBOX'
I' ve copied this library to \hmg\lib and I've added to configuration libs=hbvpdf and linking is OK now.
Hi Marek,
hbvpdf library is not included I think. :(
Try include these files in your project code or create a separate library.
hbvpdf.zip
(122.07 KiB) Downloaded 741 times
James wrote:Hi, everybody, thanks for your help, I'm having another challenge with newly installed 3.0.38:
This is because of editor.ini in IDE folder. Please delete or point your Notepad++ directory. Sorry for the inconvenience.
For console mode applications, please see the documentation for the recent note by Roberto. This is the extract:
In IDE, all build customizations must be handled by the user from 'Configuration' (project browser) tab. It is direct edit of the project .hbc file. Look at hbmk2 help for details. By default two gt drivers are ALWAYS linked: GTGUI (as default) and GTWIN (Windows console). To create console/mixed mode apps. you only must add this line to your main .prg: HB_GT_WIN_DEFAULT
When upgrading HMG, please, clean previous build data from your projects using incremental building. From command line, you must add the -clean parameter. From IDE, use the 'Reset project incremental data' option from the project menu.
