HMG4 icon disappear
l3whmg
HMG4 icon disappear
Post by l3whmg »
Hi friends, I need your help because I can't find solution.
The problem is: when I close the first window I can't see the windowicon on the second.
If I have only one form it's work fine. The problem seem to be related with ::s_lQtStarted shared var that is .F. when I fired on the second form. I have placed
   IF ::s_lQtStarted == .F.
      msgstop( cName + " ::" + hb_valtoexp( ::s_lQtStarted ) )
      HMGAPP():Start()
within the New method of window class. I receive message when the second form is fired on.
Please take a look to this little source (note remember to change the resource file and the icons name to show the problem)
FUNCTION Main
   HbQt_ErrorSys()
   HMGAPP():Resources := "stdicon"
   HMGAPP():Start()
   LoginSim()
   ShowMain()
STATIC FUNCTION ShowMain()
   LOCAL MainForm
   WITH OBJECT MainForm := Window():New( "MainForm" )
      :Row     := 10
      :Col     := 10
      :Width   := 600
      :Height  := 600
      :Title   := "MainForm title"
      :Type    := WND_MAIN
      :OnInit  := { || MainFrmOnInit() }
      :Icon    := ":L3W_ICO"
   END WITH
   MainForm:Activate()
STATIC FUNCTION MainFrmOnInit()
   THISWINDOW:Center()
STATIC FUNCTION LoginSim()
   LOCAL LoginForm
   WITH OBJECT LoginForm := Window():New( "LoginForm" )
      :Row     := 10
      :Col     := 10
      :Width   := 200
      :Height  := 200
      :Title   := "LoginForm title"
      :Type    := WND_MODAL
      :OnInit  := { || LoginFrmOnInit() }
      :Icon    := ":L3W_ICO"
   END WITH
   LoginForm:Activate()
STATIC FUNCTION LoginFrmOnInit()
   THISWINDOW:Center()
Best regards
p.s. I'm using Harbour compiler 3.x.x
Luigi from Italy
www.L3W.it
l3whmg
Re: HMG4 icon disappear
Post by l3whmg »
It's not related with Harbour 3.x.x use. I'm sure.
Cheers
Luigi from Italy
www.L3W.it
mrduck
Post by mrduck »
l3whmg wrote: LOCAL LoginForm
Can it be that when LoginForm goes out of focus you release the resources ? just an idea, not seen the code....
l3whmg
Post by l3whmg »
Hi MrDuck.
No, I don't do any release (the source it's very simple as you can see).
On the other hand, I think the problem is more complex. The shared var ::s_lQtStarted, that is enabled when we use HMGAPP():Start(), after closing the first window is .F. but must be .T. (and this mean to me: more complex).
This status var mean: QApplication and other Qt functions are fired on or not. Within window class (but I hope everywere) we test this value and: if it's .F. we call HMGAPP():Start() else it's already running. Why this test: to have HMG3 compatibility else we can call HMGAPP():Start() in top of our program. I don't remember this problem with HMG4.
I have explored all sources to find "::s_lQtStarted := .F." in a wrong place: nothing.
The only idea that I have is: when I open a new window I have a new shared var: like a new application starting.
I don't know.....
Luigi from Italy
www.L3W.it
concentra
Post by concentra »
Luigi, could you post the resource file and icon in order to me to test ?
[[]] Mauricio Ventura Faria
l3whmg
Post by l3whmg »
Hi Mauricio. Sure but I think this it's not the problem.
If you run the program with only one form (Main or Modal) work fine!
Cheers
p.s. you must change path for icon file withi resource file
XMauricio.zip
icon file and resource file
(4.71 KiB) Downloaded 245 times
Luigi from Italy
www.L3W.it
concentra
Post by concentra »
Luigi, I think this was me again... :oops:
Remember some time ago we discussed about Window class and window types, main, modal, etc.
So, at that time, to avoid multiple main type windows I coded that the first window would be forced main and any others other types.
Your first window, the one you defined as modal, was forced to be main type and, when closed, it calls HMGAPP():Quit() that was defined at QEvent_Close and Quit() restarts all shared vars...
I revised the window class code and now your sample runs Ok.
But this whole issue about window types must be deeply revised.
l3whmg
Post by l3whmg »
Hi Mauricio, great man
I remember your question and my answer now. Forget HMG3 for a moment; IMHO these rules must be respected:
1) a project can start with a WND_MODAL or a WND_MAIN form
2) a project can have only one WND_MAIN
3) when WND_MAIN will be close, HMG4 call HMGAPP():Quit() method. I THINK THIS IS WRONG we must use HMGAPP():Quit() within project, anyway...
Rule number 1) because at this moment we can't use QT single-shot (MrDuck know about this). The problem was: if I need a loginform to access?
With HMG3 I open: WND_MAIN and then WND_MODAL (it's a way) but I can close WND_MAIN if login fails
With HMG4 I can't do the same, I must: open WND_MODAL and if granted WND_MAIN. There is problem when we close a form within an OnInit event.
Thanks Mauricio.
Luigi from Italy
www.L3W.it
concentra
Post by concentra »
Hi Luigi.
l3whmg wrote:we must use HMGAPP():Quit() within project.
Why not simply end the application ?
l3whmg wrote:if I need a loginform to access?
I started working on a "dialog" class which is a simpler window, with its own loop. I will return to this asap.
l3whmg
Post by l3whmg »
Hi Mauricio
concentra wrote:Hi Luigi.
IMHO, because:
- HMGAPP():Start() fired on QApplication, register resource and... (I have introduce a StartUp procedure if you need)
- HMGAPP():Quit() shutdown QApplication, unregister resource and... (I have introduce a ShutDown procedure if you need)
I think it's always a good thing to fired on and fired off a process: QApplication. Perhaps, QT has this ability by itself: very good! Any way I prefer do.
On the other hand, but I don't have a good knowledge, in a MT program? What happen if you shutdown QApplication within the close method of a MainWindow?
In a while, a give my opinion about release topic viewtopic.php?f=32&t=2027&p=17207#p17207
Best regards
Luigi from Italy
www.L3W.it
