HMG.4 New Windows Binaries+Source Release (2011.07.18)
Updated Windows binaries containing the latest Harbour 3.0 / HBQT and HMG library.
http://www.sourceforge.net/projects/hmg
I request you to test the build and report the problems you encounter.
Thank you.
Thank you.
Re: HMG.4 New Windows Binaries+Source Release (2011.07.18)
Hi / Hola Rathinagiri :
Compila perfectamente , antes tenia problemas y ahora no los tengo.
muchas gracias por tu trabajo.
Compilation perfect, had problems before and now I have them.
thank you very much for your work.
Thanks a lot Rathi
flavio.veloso
Mr. Rathinagiri.
You have to post an updated version to linux because the last is dated 05/09/2010.
Sincerely,
Flávio Veloso.
Fortaleza - CE.
Sincerely,
Flávio Veloso.
Fortaleza - CE.
Hi Flávio Veloso,flavio.veloso wrote:Mr. Rathinagiri.
Sincerely,
Flávio Veloso.
Fortaleza - CE.
I don't have Linux machine to try and create a new version. Can somebody do that?
flavio.veloso
Thank Rathinagiri.
If someone had a script that mounts like to ask Mr. Rathinagiri post here that I do on my machine.
If they can also pass as it is mounted windows like to do here at my computer from scratch.
Sincerely,
Flávio Veloso.
Fortaleza - CE.
Sincerely,
Flávio Veloso.
Fortaleza - CE.
Flávio, este é um tópico antigo e eu já não lembro mais de tudo, mas acho que pode ajudar...
Based on information found in http://www.elart.it/links/harbourhowto_deb_en.php.
Open terminal and copy and paste :This will take some time...
Then set some qt4 related system default, typing this commands:Get Harbour source and compile from SVN trunkThis will take some time...
Install Harbour into system wide binary type:
It's not strictly need to install Harbour binaries into system files, to use Harbour without install it simply add to your
PATH enviroment variable the current path of your harbour binary, type:
and append this row:
Then to force the read of env type:
To download and build HMG4 :To build the everything demo:
To run the hbide type:
This is a mini HowTo Build from source on latest Ubuntu 11.04 clean install.Algernon wrote:What about Linux version, Is last version 05/09/2010?
sudo apt-get update; sudo apt-get install subversion wget rcs build-essential ncurses-dev libslang2-dev tk8.3-dev unixodbc-dev libncurses-dev libx11-dev libgpm-dev firebird2.1-dev libfreeimage-dev libmysqlclient15-dev libpq-dev libqt3-mt-dev liballegro4.2-dev wine dosemu-freedos mingw32 zlib1g-dev libpcre3-dev libncurses-dev libslang2-dev libx11-dev libgpmg1-dev unixodbc-dev libcurl4-gnutls-dev firebird2.1-dev libgd2-xpm-dev libsqlite3-dev libqt4-dev libwxbase2.8-dev libwxgtk2.8-dev wx-common libwebkit-dev libqt4-coreThen set some qt4 related system default, typing this commands:
sudo update-alternatives --set uic /usr/bin/uic-qt4
sudo update-alternatives --set moc /usr/bin/moc-qt4
sudo update-alternatives --set lupdate /usr/bin/lupdate-qt4
sudo update-alternatives --set lrelease /usr/bin/lrelease-qt4
sudo update-alternatives --set designer /usr/bin/designer-qt4Code: Select all
mkdir $HOME/src
cd $HOME/src
svn co https://harbour-project.svn.sourceforge.net/svnroot/harbour-project/trunk/harbour harbourCode: Select all
cd $HOME/src/harbour
export HB_BIN_INSTALL=/usr/bin
export HB_INSTALL_PREFIX=/usr/bin
export HB_LIB_INSTALL=/usr/lib/harbour
export HB_INC_INSTALL=/usr/include/harbour
export HB_DOC_INSTALL=/usr/share/doc/harbour
export HB_ETC_INSTALL=/etc/harbour
export HB_CONTRIBLIBS="hbqt hbct hbqtutils hbhpdf xhb h xml hbmzip hbzip hbxbp hbtip hbgd hbpgsql hbcurl hbmysql hbsqlit3 hbssl hbodbc rddsql gtqtc hbmisc hbcups hbziparc"
export HB_BUILD_SHARED=no
make clean
makeCode: Select all
sudo -E make installPATH enviroment variable the current path of your harbour binary, type:
cd
nano .bashrcCode: Select all
export PATH=$PATH:$HOME/src/harbour/bin/linux/gccCode: Select all
source $HOME/.bashrcCode: Select all
cd $HOME/src
svn co https://hmg.svn.sourceforge.net/svnroot/hmg hmg4
cd hmg4
hbmk2 hmg.hbpCode: Select all
cd samples/everything
hbmk2 demo_1
./demo_1Code: Select all
$HOME/src/harbour/bin/linux/gcc/./hbide[[]] Mauricio Ventura Faria
