dear all
There are 10 textbox number from text_01 ~ text_10 on main window.
I would like to get value from each textbox with loop.
So following are parts of my routin
01 for m_loop2:= 1 to 10
02 m_number:=replicate('0',2-len(alltrim(str(m_loop2,2))))+alltrim(str(m_loop2,2))
03 m_boject:=('A1C01.Text_'+m_number+'.VALUE')
04 MsgInfo(if(m_loop1==1,'1.','2.')+str(m_loop2,2)+&(m_boject))
05 next
I also try alternative way as following
04 m_object2:=&(m_boject)
05 MsgInfo(if(m_loop1==1,'1.','2.')+str(m_loop2,2)+&(m_boject2))
06 next
The same argument error on lin 04 for first way, and line 5 for second way.
Is there possible to do as I desired ?
Please Help
Best Regards
chen min
Question of convert string to control's value with marco '&'
huangchenmin
Re: Question of convert string to control's value with marco
You can try getproperty() function for this.
Syntax:
cValue := getproperty( cWindowName, cTextBoxName, "VALUE" )
In your case,
MsgInfo( GetProperty( 'A1C01', 'Text_'+m_number, 'VALUE' ) )
Syntax:
In your case,
huangchenmin
rathinagiri:rathinagiri wrote:You can try getproperty() function for this.
Syntax:
In your case,......
Thank you very very much!
chen min
