Selecting (Choosing) Folders and listing files to a listbox
nassausky
Post by nassausky »
Does anyone have a small piece of code for selecting a folder using a GetFolder GUI and sending the file listing in that folder to a listbox?
_________________
Sincerely,
Mike
nassausky
Re: Selecting (Choosing) Folders and listing files to a list
Post by nassausky »
OK I think I got it. I kept trying to do it with
aadd or afill but both those methods didn't work. I left here the small bit of code I used.
*ChooseInput is a text control which got it's value from the GetFolder function
local aDir := Directory(Main.ChooseInput.Value+"\*.*")
local x
For x:=1 to len(aDir)
  if x = 1
   Main.afiles.Item(1):=adir[x,1]
   Main.afiles.AddItem(adir[x,1])
  end if
Next
*Made an edit to the code and added an IF condition because the first item in the listbox was always blank for some reason. Who knows. If anyone knows why it wouldn't work without the manually adding an entry into the first array position give me a shout.
_________________
Sincerely,
Mike
Hi Mike
Since you did'nt give a complete (SSW) code, sadly I don't understood your problem(s) :(
But this prg works well:
PROCEDURE MAIN()
   DEFINE WINDOW frmTestDirList;
      AT 0, 0;
      WIDTH  553 ;
      HEIGHT 554 ;
      TITLE "Test DIR List" ;
      MAIN ;
      ON INIT FillDirList()
      @ 10,  100 BUTTON  btnReLoad    CAPTION "Re-Load" ACTION FillDirList()
      @ 100, 100 LISTBOX lstbxDirList WIDTH 200 HEIGHT 200
   END WINDOW // frmTestDirList
   frmTestDirList.Center
   frmTestDirList.Activate
RETURN // MAIN()
PROCEDURE FillDirList()
LOCAL cDIRName   := GetFolder( "Choose a folder" )
LOCAL aDirList   := {}
LOCAL nDirElemNo :=0
IF !EMPTY( cDIRName )
   aDirList := Directory( cDIRName )
   IF EMPTY( aDirList )
      MsgInfo( cDIRName + CRLF + " This folder doesn't contains ordinary file")
      frmTestDirList.lstbxDirList.DeleteAllItems()
      FOR nDirElemNo := 1 to LEN( aDirList )
         frmTestDirList.lstbxDirList.AddItem( aDirList[ nDirElemNo, 1 ] )
   ENDIF EMPTY( aDirList )
ENDIF !EMPTY( cDIRName )
RETURN // FillDirList()
I hope that it help you.
nassausky
Post by nassausky »
Excellent, yes thanks, I just figured it out before you posted it.
I am curious though how come you added this line
Why does the listbox create an empty item on initialization?
That's not important but I figured I would ask.
Thanks again!
_________________
Sincerely,
Mike
If you don't delete the items in the listbox, every time when you click the button, the items are added last to the listbox.
nassausky wrote:... I figured I would ask.
You are right, it's unnecessary on initialization, required when call by button.
But it's also unnecessary testing calling sequence ( called by ON INIT or BUTTON ?) and seperating process ( emty or not) within sub-procedure.
It isn't ?
