I tried to make the versatile HMG-IDE to work with the new HMG 3.0.36 test version. Once this is possible, we can bundle the new version.
While doing this, I came across some problems. I am sure somebody can solve the same easily!
1. HMG-IDE is based on build.bat residing in c:\hmg folder. So, if we can create a build.bat for hmg 3.0.36, the problem is solved.
2. The problem I face is, for all the projects in HMG 3.0.36, we have to create a file called hbmk.hbm (to point the path of hmg.hbc) which contains the library files to be included etc.,
So, basically, the functioning of HMG-IDE (where in we can specify the external libraries/include dirs etc) and HMG 3.0.36 are different. However, I am keeping on trying. If you can help, you are always welcome. Thanks in advance.
HMG 3.0.36 and HMG-IDE
