How to change the items value in the main menu
chrisjx2002
Post by chrisjx2002 »
Hello,
I want to be able to change the values of the main menu items to support different languages.
If the user chooses the english one the menu will be in english. If he wants to change it, he can do it without reloading the program... It is simple to do that when defining the main menu but after I don't know how to change it. I don't find something like Windowsname.mainmenu.item1.value := 'xxx'. How to do that?
Re: How to change the items value in the main menu
You can call any number of times 'define main menu' sequence.
Please consider this example. Created from menu.1 sample.
Function main()
	DEFINE WINDOW Form_1 ;
		WIDTH 400 ;
		HEIGHT 200 ;
		TITLE 'Menu Test' ;
		MAIN
		DEFINE MAIN MENU
			POPUP 'File'
				ITEM 'Open' 		ACTION MsgInfo ('File:Open') IMAGE 'Check.Bmp'
				ITEM 'Save' 		ACTION MsgInfo ('File:Save') IMAGE 'Free.Bmp'
				ITEM 'Print' 		ACTION MsgInfo ('File:Print') IMAGE 'Info.Bmp'
				ITEM 'Save As...' 	ACTION MsgInfo ('File:Save As')
				ITEM 'HMG Version' 	ACTION MsgInfo (HMGVersion())
				SEPARATOR
				ITEM 'Exit' 		ACTION MsgInfo ('File:Exit') IMAGE 'Exit.Bmp'
			END POPUP
			POPUP 'Test'
				ITEM 'Item 1' 		ACTION MsgInfo ('Item 1')  name xxx
				ITEM 'Item 2' 		ACTION MsgInfo ('Item 2')
				POPUP 'Item 3' name test
					ITEM 'Item 3.1' 		ACTION MsgInfo ('Item 3.1')
					ITEM 'Item 3.2' 		ACTION MsgInfo ('Item 3.2')
					POPUP 'Item 3.3'
						ITEM 'Item 3.3.1' 		ACTION MsgInfo ('Item 3.3.1')
						ITEM 'Item 3.3.2' 		ACTION MsgInfo ('Item 3.3.2')
						POPUP 'Item 3.3.3'
							ITEM 'Item 3.3.3.1' 		ACTION MsgInfo ('Item 3.3.3.1')
							ITEM 'Item 3.3.3.2' 		ACTION MsgInfo ('Item 3.3.3.2')
							ITEM 'Item 3.3.3.3' 		ACTION MsgInfo ('Item 3.3.3.3')
							ITEM 'Item 3.3.3.4' 		ACTION MsgInfo ('Item 3.3.3.4')
							ITEM 'Item 3.3.3.5' 		ACTION MsgInfo ('Item 3.3.3.5')
							ITEM 'Item 3.3.3.6' 		ACTION MsgInfo ('Item 3.3.3.6')
						END POPUP
						ITEM 'Item 3.3.4' 		ACTION MsgInfo ('Item 3.3.4')
					END POPUP
				END POPUP
				ITEM 'Item 4' 		ACTION MsgInfo ('Item 4')
			END POPUP
			POPUP 'Help'
				ITEM 'About' 		ACTION MsgInfo ('Help:ABout')
			END POPUP
		END MENU
		DEFINE CONTEXT MENU
			SEPARATOR
			ITEM 'Item 3' 		ACTION MsgInfo ('Item 3')
		END MENU
		define button new
		   row 100
		   col 10
		   caption 'Click'
		   action newmenu()
		end button
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
function newmenu
		DEFINE MAIN MENU of Form_1
			POPUP 'File1'
				ITEM 'Open1' 		ACTION MsgInfo ('File:Open') IMAGE 'Check.Bmp'
				ITEM 'Save1' 		ACTION MsgInfo ('File:Save') IMAGE 'Free.Bmp'
				ITEM 'Print1' 		ACTION MsgInfo ('File:Print') IMAGE 'Info.Bmp'
				ITEM 'Save As...1' 	ACTION MsgInfo ('File:Save As')
				ITEM 'HMG Version1' 	ACTION MsgInfo (HMGVersion())
				SEPARATOR
				ITEM 'Exit1' 		ACTION MsgInfo ('File:Exit') IMAGE 'Exit.Bmp'
			END POPUP
			POPUP 'Test1'
				ITEM 'Item 11' 		ACTION MsgInfo ('Item 1')  name xxx
				ITEM 'Item 21' 		ACTION MsgInfo ('Item 2')
				POPUP 'Item 31' name test
					ITEM 'Item 3.11' 		ACTION MsgInfo ('Item 3.1')
					ITEM 'Item 3.21' 		ACTION MsgInfo ('Item 3.2')
					POPUP 'Item 3.31'
						ITEM 'Item 3.3.11' 		ACTION MsgInfo ('Item 3.3.1')
						ITEM 'Item 3.3.21' 		ACTION MsgInfo ('Item 3.3.2')
						POPUP 'Item 3.3.31'
							ITEM 'Item 3.3.3.11' 		ACTION MsgInfo ('Item 3.3.3.1')
							ITEM 'Item 3.3.3.21' 		ACTION MsgInfo ('Item 3.3.3.2')
							ITEM 'Item 3.3.3.31' 		ACTION MsgInfo ('Item 3.3.3.3')
							ITEM 'Item 3.3.3.41' 		ACTION MsgInfo ('Item 3.3.3.4')
							ITEM 'Item 3.3.3.51' 		ACTION MsgInfo ('Item 3.3.3.5')
							ITEM 'Item 3.3.3.61' 		ACTION MsgInfo ('Item 3.3.3.6')
						END POPUP
						ITEM 'Item 3.3.41' 		ACTION MsgInfo ('Item 3.3.4')
					END POPUP
				END POPUP
				ITEM 'Item 41' 		ACTION MsgInfo ('Item 4')
			END POPUP
			POPUP 'Help1'
				ITEM 'About1' 		ACTION MsgInfo ('Help:ABout')
			END POPUP
		END MENU
return nil
chrisjx2002
Super! Thanks a lot. I didn't know that it was possible to redefine the main menu like this.
Me too!
You are welcome!
