Hi all,
I can create objects using macro substituion:
@ nRow, 140 LABEL &cGLabel ;
I tried release them using the same but failed. How should I do it?
cGLabel := 'Main.Label_'+AllTrim(Str(nI),1)+'.Release'
&cGLabel
Thanks.
Release objects using macro
Re: Release objects using macro
Hi,raymanw wrote:Hi all,
&cGLabel
Try
cForm := "Main"
cGLabel := "Label_"+AllTrim(Str(nI),1)
DoMethod(cForm, cGLabel, "Release")
Hope that helps
Thanks Grigory.
Hi gfilatov
It worked. Thanks.
It worked. Thanks.
How can I use the same to enable/disable an object?
Thanks.
Thanks.
I think, you can use Visible property:
SetProperty(cWindowName, cControlName, "VISIBLE", .f.)
Hi mol,
Thanks for the solution.
