Dear all
I would like to build a app that could send the result vis email in background.
Therefore I could receive result daily and know the progress.
How do I do to send email? excute outlook ?
Please Help!
Best Regards
chen min
How to send email via hmg program ?
Re: How to send email via hmg program ?
No, we need not use Outlook.
We can use HBTIP instead. Here you can see samples too.
http://hmgforum.com/viewtopic.php?f=5&t=260
huangchenmin
Dear rathinagiri:rathinagiri wrote:No, we need not use Outlook.
Thanks for your support.
Should I need to include C:\hmg\HARBOUR\lib\libhbtip.a other than HMG.ch ?
I didi noe see the 『include C:\hmg\HARBOUR\lib\libhbtip.a』in sample.
Best Regards
chen min
IMHO, it is already included in the linking process. We can straight away use the functions.
huangchenmin
Thank you very much!rathinagiri wrote:IMHO, it is already included in the linking process. We can straight away use the functions.
Best Regards
I'm using such a code:
(You need to change your account and password)
function SendMail
param cSubject, cBody
LOCAL oMail, cData, i, oAttach
local lret
local xto := "akord@mol-systemy.nazwa.pl"
local cFrom := "akord@kern-liebers.nazwa.pl"
local cServer := "kern-liebers.nazwa.pl"
local nPort := 587
local xCC := "mol@pro.onet.pl"
local xBCC := "mol68@tlen.pl"
local aFiles := NIL
local cUser := "akord@kern-liebers.nazwa.pl"
local cPass := "************"
local cPopServer := "kern-liebers.nazwa.pl"
local nPriority := 1
local lRead := .f. // confirmation request
local bTrace := .f. //create transmission log?
local lPopAuth := .f. // login into POP server
local lNoAuth := .f.
local nTimeOut := 500
local cReplyTo := ""
local lTLS := .f. // do not change! causes crash!
local cSMTPPass := "***********"
local cCharset := "windows-1250"
local cEncoding := ""
cBody += eol + dtoC(date())+" "+time()
WAIT WINDOW "Trwa wysyłanie wiadomości e-mail: " + cBody NOWAIT
lret := hb_SendMail( cServer, nPort, cFrom, xTo, xCC, xBCC, cBody, cSubject, aFiles, cUser, cPass, cPopServer,;
nPriority, lRead, bTrace, lPopAuth, lNoAuth, nTimeOut, cReplyTo, lTLS, cSMTPPass, cCharset, cEncoding )
cServer -> Required. IP or domain name of the mail server
nPort -> Optional. Port used my email server
cFrom -> Required. Email address of the sender
xTo -> Required. Character string or array of email addresses to send the email to
xCC -> Optional. Character string or array of email adresses for CC (Carbon Copy)
xBCC -> Optional. Character string or array of email adresses for BCC (Blind Carbon Copy)
cBody -> Optional. The body message of the email as text, or the filename of the HTML message to send.
cSubject -> Optional. Subject of the sending email
aFiles -> Optional. Array of attachments to the email to send
cUser -> Required. User name for the POP3 server
cPass -> Required. Password for cUser
cPopServer -> Required. POP3 server name or address
nPriority -> Optional. Email priority: 1=High, 3=Normal (Standard), 5=Low
lRead -> Optional. If set to .T., a confirmation request is send. Standard setting is .F.
bTrace -> Optional. If set to .T., a log file is created (smtp-<nNr>.log). Standard setting is NIL.
If a block is passed, it will be called for each log event with the message a string, no param on session close.
lPopAuth -> Optional. Do POP3 authentication before sending mail.
lNoAuth -> Optional. Disable Autentication methods
nTimeOut -> Optional. Number os ms to wait default 20000 (20s)
cReplyTo -> Optional.
WAIT CLEAR
RETURN lret
huangchenmin
Sorry for reply late.mol wrote:I'm using such a code:
function SendMail ........
I been busy for urgen project.
I will read your code lately.
Best Regards
chen min
