HMG application forms help
raymanw
Post by raymanw »
Hi all,
I am quite new to Harbour & HMG. I have successfully created the main form, a dropdown menu, a indexing form with a progress bar and is working on an user entry form. All this thanks to good people, like CCH, who are kind enough to help me out & also the good examples under the samples folder in the HMG package.
My question:
When I call my indexing form from the dropdown menu, it opens a new window outside & on top of the main form. How can I utilizes only 1 form to accomplish the same? ie. I start the application, the main form opens, I then call the indexing form & I don't want a new window/form to appear but have the progress bar rendered in the same main form.
Or the alternative is to have the indexing form/window opens within the confine of the main form.
Which one or both are doable? Which one is easier?
Thanks.
Re: HMG application forms help
You can have the progress bar rendered in the same main form.
Instead of creating the forms in the runtime, we have to create controls at runtime. Use the 'Parent' for defining a new control at runtime. I will post a small sample soon.
raymanw
Post by raymanw »
Hi Rathinagiri,
I managed to get the objects to render on the main window by following the example in this topic: http://hmgforum.com/viewtopic.php?f=5&t ... lit=parent
However, after the processing had finished, how do I clear the form?
Thanks.
raymanw
Post by raymanw »
I did a release of the 3 objects specified:
Main.Progress_1.Release
Main.TextBox_1.Release
Main.TextBox_2.Release
Progress_1 disappeared but the other 2 still remains.
Also, is it possible to clear the window of the 3 objects at one go?
Thanks.
Hi Can you give me the sample code?
I wish to know about your HMG version also.
raymanw
Post by raymanw »
Hi Rathinagiri,
My HMG version is 3.0.35.
Part of the code:
Function IndexFile
	declare window Main
	@ 70,31 PROGRESSBAR Progress_1 ;
		parent Main ;
		RANGE 0,100 ;
		WIDTH 300 HEIGHT 26 ;
		TOOLTIP "ProgressBar"
	@ 120,155 TEXTBOX TextBox_1 ;
		parent Main ;
		VALUE " 0 %" WIDTH 60 MAXLENGTH 5
	@ 170,31 TEXTBOX TextBox_2 ;
		parent Main ;
		VALUE " 0 %" WIDTH 300 MAXLENGTH 5
	Main.Progress_1.BackColor := YELLOW
	Main.Progress_1.ForeColor := BLUE
	Main.TextBox_1.Enabled := .f.
	Main.TextBox_2.Enabled := .f.
	Main.TextBox_2.Value := "Re-arranging Stock Transactions Headers (I)."
	use StkHeads
	inde on StkHeads->type+StkHeads->reference           to StkHeads
	Main.TextBox_1.Value := Str(44,3)+" %"
	Main.Progress_1.Value := 44
	Main.TextBox_2.Value := "Re-arranging Stock Transactions Details (I)."
	use StkTrans
	inde on StkTrans->type+StkTrans->reference+StkTrans->gold_type+StkTrans->item_type+StkTrans->item to StkTrans
	Main.TextBox_1.Value := Str(67,3)+" %"
	Main.Progress_1.Value := 67
	Main.TextBox_2.Value := "Re-arranging Serial Number."
	use Serial
	pack
	inde on Serial->gold_type+Serial->item_type to Serial
	Main.TextBox_1.Value := Str(100,3)+" %"
	Main.Progress_1.Value := 100
	Main.TextBox_2.Value := "Re-arranging Completed."
	close
Please check is code. The textboxes are released correctly for me.
define window sample at 0,0 width 800 height 600 main
   define button b1
      row 10
      col 10
      caption "Press Me"
      action showprogressbar()
   end button
end window
sample.center
sample.activate
function showprogressbar
   define progressbar p1
      row 100
      col 100
      width 200
      parent sample
      value 0
   end progressbar
   define textbox t1
      parent sample
      row 240
      col 10
      width 100
      numeric .t.
      rightalign .t.
      value 0
   end textbox
   define textbox t2
      parent sample
      row 270
      col 10
      width 100
      numeric .t.
      rightalign .t.
      value 0
   end textbox
   For i := 1 to 100
      sample.t1.value := i
      for j := 1 to 200
         sample.t2.value := j
      next j
      sample.p1.value := i
   next i
   sample.p1.release
   sample.t1.release
   sample.t2.release
return nil
raymanw
Post by raymanw »
Hi Rathinagiri,
I tried your code, copy & pasted as sample1.prg & build using the command: c:\hmg.3.0.35\build.bat sample1
I do see the progress bar but don't see the 2 textboxes. The progress bar do disappeared after the run.
Thanks.
In that case, please use the following code with 'Do Events'
   define button b1
      row 10
      col 10
      caption "Press Me"
   end button
end window
sample.center
sample.activate
      row 100
      col 100
      width 200
      parent sample
      value 0
   end progressbar
   define textbox t1
      parent sample
      row 240
      col 10
      width 100
      numeric .t.
      rightalign .t.
      value 0
   end textbox
   define textbox t2
      parent sample
      row 270
      col 10
      width 100
      numeric .t.
      rightalign .t.
      value 0
   end textbox
   For i := 1 to 100
      for j := 1 to 200
         DO EVENTS
      next j
   next i
   sample.p1.release
   sample.t1.release
   sample.t2.release
return nil
raymanw
Post by raymanw »
Hi Rathinagiri,
Thanks for the working example.
Much appreciated.
