How to compile a HMG apps using Harbour hbmk2 ?
Hi All
If I want to compile a HMG app using hbmk2, how will the HmgProject.hbp look like ?
Cheers
CCH
http://cch4clipper.blogspot.com
Cheers
CCH
Re: How to compile a HMG apps using Harbour hbmk2 ?
Hi CCH,
I don't know if this is a good way, but I use it for my project. On the other hand you must consider you installation and path to have the ability to call hbmk2.
Well, this is my simple project.hbp file where I put all .prg files (or you can insert .c files)
I hope this can be usefull for you.
Best regard
Inside otherfile.hbc (is optional, but I think usefull), you can also tell "Include paths", "libraries paths" and "libraries name" to add; example I write my personal library and include file and for this I insert inside .hbc. N.B. libraries name must be blank separated-w3 -es2
otherfile.hbc
gacqp000.prg
gacqp001.prg
gacqp002.prg
gacqp003.prg
gacqp004.prg
Now you can call "hbmk2 myproject.hbp". But remember: you must pay attention to have correct path in your environment vars or create a good batch command. I prefer second way!incpaths=D:\HMG\L3wSys\Lib
libpaths=D:\HMG\L3wSys\Lib
libs=l3w_dbf
Best regard
Luigi from Italy
www.L3W.it
www.L3W.it
Hi Luigi
TQVM for responding.
Yeah, your method is quite practical but what I was really asking is the names of the HMG libs that must be included in the hbp file.
For example, if I want to link in Xharbour code, I add
xhb.hbc
hbxpp.hbc
What I am puzzled is that using the HMG IDE, the project hbp file only contains my prg and no references to any HMG specific libs.
eg
frs4W764.prg
locks.prg
So when i hbmk2 frs4w764.hbp, I get
C:\hmg.3.0.35\PROJECTS\FRS4W764>hbmk2 frs4w764.hbp
Harbour 2.1.0rc1 (Rev. 16282)
Copyright (c) 1999-2011, http://harbour-project.org/
Compiling 'frs4W764.prg'...
frs4W764.prg(146) Error F0029 Can't open #include file 'minigui.ch'
hbmk2: Error: Running Harbour compiler (embedded). 1
(c:\hb21\bin\harbour.exe) -n2 frs4W764.prg locks.prg -oC:\Users\CCH\AppData\Loca
l\Temp\hbmk_3lhr70.dir\ -ic:\hb21\include
But if I use HMG-IDE to open frs4w764.hbp, I can successfully build frs4w764.exe
Can anyone clarify this ?
TIA
CCH
xhb.hbc
hbxpp.hbc
eg
frs4W764.prg
locks.prg
TIA
CCH
Hi CCH,
I hope understand your problem. First of all: I don't use HMG-IDE!
In my previous post, I write about a good batch command! I derived from standard command build.bat; complete version it's compicated because, with the same command, I can: create lib or add/create resource file. For these reasons I write main pieces. Any way, this is my skeleton:
1) Preserve current path, add Hmg environment path and some compiler flags
2) Call hbmk2
3) Restore previous path
CODE 1)
N.B. you must do changes regarding your installation; I have installed HMG3 on partition D:
CODE 2)
N.B.
A) I'm using stdout to create log file: look at ">hbmk.log 2>&1". I don't use redir like in build .bat
B) You can see "-l" flag with libraries names: I inserted the minimu required
C) Look at -incpath and -L and related vars
D) take a look to the %prgflag%, %cflag% etc. I've inserted into the .bat but can be inserted/altered inside "hbp"
E) take a look to the %hmgres% var: can store standard hmg.o file or your if I you have one compiled with "windres" command.
CODE 3)
sounds like cleanup
I hope this it's clear (take a look to the build.bat standard command) if not, I can send you complete version with PM.
2) Call hbmk2
CODE 1)
SET tpath=%PATH%
SET hmgpath=D:\HMG\MiniGui
SET PATH=%hmgpath%\util;%hmgpath%\mingw\bin;%hmgpath%\harbour\bin;
SET hmgres=%hmgpath%\resources\hmg.o
SET gui=-gtgui
SET mt=
SET prgflag=-prgflag=/q /w0 /es2
SET cflag=-cflag=-O3
CODE 2)
hbmk2 -o%~n1.exe %prgflag% %cflag% %gui% %mt% -incpath=%HmgPath%\include -L%HmgPath%\lib -lhmg -lhbmzip -lhbwin -lhbct -lhbmisc -lxhb -lvfw32 -lmsvfw32 %1 %hmgres% >hbmk.log 2>&1
IF ERRORLEVEL 1 GOTO error04
CODE 3)
sounds like cleanup
SET PATH=%tpath%
SET tpath=
SET hmgpath=
SET hmgres=
SET gui=
SET mt=
SET prgflag=
SET cflag=
Luigi from Italy
www.L3W.it
www.L3W.it
Hi Luigi
Thanks again for a speedy response !
I get the idea... pretty complicated compared to using hbmk2 to compile a HB21 +gtWVG app ie just adding -gtWVG and gtGUI to myproject.hbp file and then just calling hbmk2 myproject.hbp
Cheers
CCH
Cheers
CCH
Hi CCH,I'm sorry I dont's understand very well your replay
Any way if the problem is to have all options inside hbp, here is an example.hbp:
and this can be batch command
N.B.
A) in this way you have a fixed GUI; with .bat you can use/intercept a parameter and change. I don't know if there is the ability to give a parameter to the .hbp file!
B) HB_TARGETNAME is an environment var used in HBMK2 (there are many others!)
C) about resources there are many possibilities ( .rc or .o file) but I must investigate
D) hbmk2 can manage: .hbp, .hbm, .hbc At this moment I don't have a clear idea
E) with otherfile.hbc you can add extra libs and include
I think hbmk2 doc is very small and not clear (for me!)
Cheers
-o${hb_targetname}.exe
-prgflag=-w3 -es2 -gtgui
-cflag=-O3
-incpath=D:\HMG\MiniGui\include
-L=D:\HMG\MiniGui\lib
otherfile.hbc
prg1.prg
prg2.prg
SET tpath=%PATH%
SET HB_TARGETNAME=%~n1
hbmk2 %1 %hmgres% >hbmk.log 2>&1
SET PATH=%tpath%
SET tpath=
SET hmgpath=
SET hmgres=
SET HB_TARGETNAME=
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
Hi Luigi
Are all the above libs necessary to compile a HMG app ?
CCH
CCH
Hi CCH,
IMO yes. I created this list using the method of including step by step. I have found that:
- Hmg obviously
- hbmzip, hbct, hbmisc, xhb from Harbour pack
- vfw32, msvfw32 from MinGw pack
Maybe it's possible that someone is not essential for your program
, but you can try excluding one at a time.
In addition, I have tried to compile HMG3 with the new version of the Harbour compiler but I got many warning with the option /w0 (with /w3, of course, does not generate the hmg library). The generation of an executable is, in any case, impossible for many mistakes: for example with hbmzip (used by Hmg).
Cheers
- Hmg obviously
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
Hi CCH,
I have provided to you inaccurate information.
First: these libraries are required to use standard HMG.
Second: with HMG are also distributed other libraries: libcrypt, libedit, libeditex, libgraph, and so on. If you use commands that come from these libraries you must add them to the compilation command (ex. drawline() come from libgraph).
Third: Harbour adds other libraries, but I have not been able to discover the list
Cheers
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
Hi Luigi
I tried
frs4hmg.hbp
-prgflag= -w3 -es2 -gtgui
-cflag=-O3
frs4hmg.hbc
frs4w764.prg
locks.prg
frs4hmg.hbc
incpaths=c:\hmg\include
libpaths=c:\hmg\lib
libs=
gt=
mt=no
instpaths=
Resultant Error Messages
C:\hmg.3.0.35\PROJECTS\FRS4W764>hbmk2 frs4hmg.hbp
Compiling 'frs4w764.prg'...
Lines 20466, Functions/Procedures 27
Generating C source output to 'C:\Users\CCH\AppData\Local\Temp\hbmk_dtvp0k.dir\f
rs4w764.c'... Done.
Compiling 'locks.prg'...
Lines 157, Functions/Procedures 4
Generating C source output to 'C:\Users\CCH\AppData\Local\Temp\hbmk_dtvp0k.dir\l
ocks.c'... Done.
c:/hb21/lib/win/mingw/libhbwin.a(legacycd.o):legacycd.c:(.text+0x0): multiple de
finition of `HB_FUN_GETLASTERROR'
c:/hmg/lib/libhmg.a(c_winapimisc.o):c_winapimisc.c:(.text+0xcbc): first defined
here
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x12): undefined referen
ce to `unzClose'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x48): undefined referen
ce to `zipClose'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x7b): undefined referen
ce to `unzOpen'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0xda): undefined referen
ce to `zipOpen'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x105): undefined refere
nce to `unzGetGlobalInfo'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x12c): undefined refere
nce to `unzGoToFirstFile'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x158): undefined refere
nce to `unzGoToNextFile'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x19c): undefined refere
nce to `unzGetCurrentFileInfo'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x220): undefined refere
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x253): undefined refere
nce to `unzOpenCurrentFile2'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x26f): undefined refere
nce to `unzGetLocalExtrafield'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x29c): undefined refere
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x385): undefined refere
nce to `zipOpenNewFileInZip2'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x3d8): undefined refere
nce to `zipWriteInFileInZip'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x403): undefined refere
nce to `unzReadCurrentFile'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x476): undefined refere
nce to `zipClose'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x47e): undefined refere
nce to `unzClose'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x4cf): undefined refere
nce to `unzClose'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x4fe): undefined refere
nce to `zipCloseFileInZipRaw'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x50e): undefined refere
nce to `unzCloseCurrentFile'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x55e): undefined refere
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x5bf): undefined refere
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x625): undefined refere
nce to `unzGetGlobalComment'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x6fa): undefined refere
nce to `zipClose'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x77e): undefined refere
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x7a1): undefined refere
nce to `unzOpenCurrentFilePassword'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x85a): undefined refere
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x8e4): undefined refere
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0xc54): undefined refere
nce to `zipOpen2'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0xd1d): undefined refere
nce to `zipClose'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0xfc2): undefined refere
nce to `zipOpenNewFileInZip3'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x1133): undefined refer
ence to `zipWriteInFileInZip'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x1206): undefined refer
ence to `zipCloseFileInZip'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x1268): undefined refer
ence to `unzOpen'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x130c): undefined refer
ence to `unzClose'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x1398): undefined refer
ence to `unzGetGlobalInfo'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x13fb): undefined refer
ence to `unzGetGlobalComment'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x14e6): undefined refer
ence to `unzGoToFirstFile'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x1556): undefined refer
ence to `unzGoToNextFile'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x15c6): undefined refer
ence to `unzGetOffset'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x1647): undefined refer
ence to `unzSetOffset'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x16f9): undefined refer
ence to `unzGetCurrentFileInfo'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x18bb): undefined refer
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x1ad7): undefined refer
ence to `unzOpenCurrentFilePassword'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x1c00): undefined refer
ence to `unzReadCurrentFile'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x1c46): undefined refer
ence to `unzCloseCurrentFile'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x1ef3): undefined refer
ence to `zipOpenNewFileInZip3'
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x2039): undefined refer
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x213c): undefined refer
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x216b): undefined refer
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x2207): undefined refer
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x2440): undefined refer
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x24ce): undefined refer
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x2501): undefined refer
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x2642): undefined refer
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x2688): undefined refer
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x26d1): undefined refer
c:/hb21/lib/win/mingw/libhbmzip.a(mzip.o):mzip.c:(.text+0x27a4): undefined refer
c:\hb21\comp\mingw\bin\gcc.exe C:/Users/CCH/AppData/Local/Temp/hbmk_dtvp0k.dir/f
rs4w764.o C:/Users/CCH/AppData/Local/Temp/hbmk_dtvp0k.dir/locks.o C:/Users/CCH/A
ppData/Local/Temp/hbmk_dtvp0k.dir/hbmk_jkjf91.o -mwindows -Wl,--start-group -
lhmg -lhbmzip -lhbwin -lhbct -lhbmisc -lxhb -lvfw32 -lmsvfw32 -lhbextern -lhbdeb
ug -lhbvm -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lg
tgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -
lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luse
r32 -lgdi32 -ladvapi32 -lws2_32 -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luui
d -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre
-lhbzlib -Wl,--end-group -ofrs4hmg.exe -Lc:/hb21/lib/win/mingw -Lc:/hb21/bin
-Lc:/hmg/lib
Any suggestions ?
CCH
I tried
frs4hmg.hbp
-cflag=-O3
frs4hmg.hbc
frs4w764.prg
locks.prg
frs4hmg.hbc
libpaths=c:\hmg\lib
libs=
gt=
mt=no
instpaths=
rs4w764.c'... Done.
ocks.c'... Done.
here
ce to `unzClose'
ce to `zipClose'
ce to `unzOpen'
ce to `zipOpen'
nce to `zipClose'
nce to `unzClose'
nce to `unzClose'
nce to `zipClose'
nce to `zipOpen2'
nce to `zipClose'
ence to `unzOpen'
ence to `unzClose'
-Lc:/hmg/lib
Any suggestions ?
CCH
