HMG.4 New Windows Binaries+Source Release (2011.02.01)
Updated Windows binaries containing the latest Harbour/HBQT and HMG library.
http://www.sourceforge.net/projects/hmg
I request you to test the build and report the problems you encounter.
Thank you.
Re: HMG.4 New Windows Binaries+Source Release (2011.02.01)
Thanks a lot Rathi :)
As said very recently, you are our second-chairman :D
Best regards
Hi Esgici,
IMO, I am in no way near comparison to second-chairman.
pctoledo
Post by pctoledo »
I tried several times copy the file, but without success!
When you run the installer this error occurs:
Toledo
Clipper On Line
Is it?!
Let me download and check.
Dear Mr. Rathinagiri,
Same error message when trying to install it, as Mr. Toledo reported.
sniff sniff :cry:
Please wait. I have verified before uploading the file. But I had not verified by downloading and installing. :(
I am uploading it again.
Once I download and check I will announce here.
I am terribly sorry for the inconvenience. :(
Now I have re-uploaded, re-downloaded and verified. It works fine now.
Thanks for reporting.
pctoledo
Post by pctoledo »
Hi rathinagiri,
The file is still with error!
The download starts and then gives an error. But as I use Opera, I can continue downloading from where it stopped, and so copied the entire file.
VirtualGrid was very good!
The only thing missing implemented Enter and set navigation extended.
See: http://hmgforum.com/viewtopic.php?p=15430#p15430
Toledo
Clipper On Line
Download and installation now it´s working fine. Thanks Rathinagiri
