Picture Property
Picture Property
Hi :
I'm trying to figure out how it works Picture Property
<ParentWindowName>.<ControlName>.Picture := cImageName
<ParentWindowName>.<ControlName>.Picture --> cImageName
container TAB accepted indices as a reference to the page I mean
 this works     Principal.Container_Tab(nX).&(cImage).Width   := Principal.Width - 30
however does not       Principal.Container_Tab(nPage).Picture := "Unselect.bmp"
I find no specific example of property management within the container TAB pages
only simple WindowName.ControlName.Value
or a little more complex Form_1.Tab_1 (1). Grid_1.Caption (1) in ..\hmg.3.0.35\SAMPLES\MAIN.DEMO
Español
estoy intentando saber como funciona Picture Property
el contenedor TAB acepta indices como referencia a la pagina que me refiero
esto funciona    Principal.Container_Tab(nX).&(cImage).Width   := Principal.Width - 30
sin enbargo esto no          Principal.Container_Tab(nPage).Picture := "Unselect.bmp"
no encuentro ejemplo especificos del manejo propiedades de paginas dentro del contenedor TAB
solo el simple WindowName.ControlName.Value
o un poco mas complejo Form_1.Tab_1(1).Grid_1.Caption(1) en ..\hmg.3.0.35\SAMPLES\MAIN.DEMO
Saludos / Greetings
Re: Picture Property
Hello Daniel,
Please take a look for updated sample from your folder \hmg\samples\CONTAINERS\Tab below:
 * Copyright 2008 Roberto Lopez <mail.box.hmg@gmail.com>
 * http://sites.google.com/site/hmgweb/
Local aRows [20] [3]
	aRows [1]	:= {'Simpson','Homer','555-5555'}
	aRows [2]	:= {'Mulder','Fox','324-6432'}
	aRows [3]	:= {'Smart','Max','432-5892'}
	aRows [4]	:= {'Grillo','Pepe','894-2332'}
	aRows [5]	:= {'Kirk','James','346-9873'}
	DEFINE WINDOW Form_1 ;
		WIDTH 640 HEIGHT 480 ;
		TITLE 'HMG Demo' ;
		MAIN
		DEFINE MAIN MENU
			DEFINE POPUP 'Test'
				MENUITEM 'Get Image Picture' ACTION MsgInfo ( Form_1.Tab_1(1).Image_1.Picture )
				MENUITEM 'Set Image Picture' ACTION Form_1.Tab_1(1).Image_1.Picture := 'hmg.gif'
				SEPARATOR
				MENUITEM 'Get Button Caption' ACTION MsgInfo ( Form_1.Tab_1(1).Button_1.Caption )
				MENUITEM 'Set Button Caption' ACTION Form_1.Tab_1(1).Button_1.Caption := 'New'
				SEPARATOR
				MENUITEM 'Get Grid Header' ACTION MsgInfo ( Form_1.Tab_1(4).Grid_1.Header(1) )
				MENUITEM 'Set Grid Header' ACTION Form_1.Tab_1(4).Grid_1.Header(1) := 'New'
				SEPARATOR
				MENUITEM 'Set Grid Cell' ACTION Form_1.Tab_1(4).Grid_1.Cell(1,1) := 'New'
				MENUITEM 'Get Grid Cell' ACTION MsgInfo ( Form_1.Tab_1(4).Grid_1.Cell(1,1) )
				SEPARATOR
				MENUITEM 'Show Button' ACTION Form_1.Tab_1(1).Button_1.Show()
				MENUITEM 'Hide Button' ACTION Form_1.Tab_1(1).Button_1.Hide()
			END POPUP
		END MENU
		DEFINE TAB Tab_1 ;
			AT 10,10 ;
			WIDTH 600 ;
			HEIGHT 400 ;
			VALUE 1 ;
			TOOLTIP 'Tab Control'
			PAGE 'Page 1' IMAGE "exit.bmp"
				DEFINE IMAGE Image_1
					ROW	40
					COL	10
					HEIGHT	110
					WIDTH	230
					PICTURE	'demo.gif'
					STRETCH	.F.
				END IMAGE
			      @ 100,250 BUTTON Button_1 CAPTION "Test" WIDTH 50 HEIGHT 50 ACTION MsgInfo('Test!')
			END PAGE
			PAGE 'Page &2' IMAGE "info.bmp"
				DEFINE RADIOGROUP R1
					ROW	100
					COL	100
					OPTIONS	{ '1','2','3' }
					VALUE	1
				END RADIOGROUP
			END PAGE
			PAGE 'Page 3' IMAGE "check.bmp"
				@ 100,250 SPINNER Spinner_1 ;
				RANGE 0,10 ;
				VALUE 5 ;
				WIDTH 100 ;
				TOOLTIP 'Range 0,10' ;
				ON CHANGE PlayBeep()
			END PAGE
			PAGE 'Page 4' IMAGE "button.bmp"
				@ 50,50 GRID Grid_1 ;
					WIDTH 200 ;
					HEIGHT 330 ;
					HEADERS {'Last Name','First Name','Phone'} ;
					WIDTHS {140,140,140};
					ITEMS aRows ;
					VALUE 1
			END PAGE
		END TAB
	Form_1.Center
	Form_1.Activate
Hope that give you an idea :idea:
Hi Grigory :
try this
Procedure UnSelectPage()
 FOR nCounter := 1 TO nPage - 1
     Principal.Container_Tab(nCounter).Picture := "Unselect.bmp"
to select a tab page of the other pages should display an image
"Unselect".
danielmaximiliano wrote:Hi Grigory :
try this
"Unselect".
Hi Daniel,
You are right!
The official HMG have only 'Caption(nPage)' property of Tab's pages for dynamical change at runtime.
BTW There is Image property of Tab's pages in the HMG Extended Edition, i.e.
Form_1.Tab_1.Image( 1 ) := 'Unselect.Bmp'
Thanks Grigory
Extended tonight proves
Saludos / Regard
Hi Everyone:
Find in HMG.4 I can add a picture of PAGE, PAGE disable you want, give Backcolor the TAB or PAGE, is whether ... all I wanted to do in HMG3.x and could not.
 Page1: Image: = 'open.png'
Tab1: Position: = TAB_TOP
Tab1: Shape: = TAB_TRIANGULAR
Example I am now migrating to take on new qualities of HMG.4 with QT.
Greetings
Español
Hola a Todos :
Encontre en HMG.4 que puedo agregar una imagen del PAGE, desactivar los PAGE que quiera, dar el Backcolor al TAB o al PAGE, es si... todo lo que queria hacer en HMG3.x y no podia.
 Page1:Image := 'open.png'
Tab1:Position := TAB_TOP
Tab1:Shape   := TAB_TRIANGULAR
ahora estoy migrando el Ejemplo para asumir las nuevas cualidades de HMG.4 con QT.
