Enter in TextBox and Button
pctoledo
Post by pctoledo »
Enter does not work in TextBox and Button!
Enter in the TextBox does nothing:
		With Object oSenha	:= TextBox():New()
			:Row		:= 80
			:Col		:= 170
			:Width		:= 181
			:Height		:= 20
			:Password 	:= .t.
			:OnEnter	:= { || MsgInfo("Enter") }
		End With
Button only works with mouse click:
		With Object oButton1 := Button():New()
			:Row		:= 142
			:Col		:= 280
			:Caption	:= 'Sair'
			:OnClick	:= { || MsgInfo("Enter") }
		End With
Clause NoSize not work in Window:
	With Object oModalSenha := Window():New()
		:Row		:= 0
		:Col		:= 0
		:Width		:= 390
		:Height		:= 178
		:Title		:= 'Sistema de Ficha Qualificativa'
		:Type		:= WND_MAIN
		:OnInit		:= { || ( oModalSenha:Center() ) }
		:Sizable	:= .F.
		:MaxButton	:= .F.
		:MinButton	:= .F.
	End With
Toledo
Clipper On Line
Re: Enter in TextBox and Button
Yes. Enter and set navigation extended are not implemented as such.
pctoledo
Post by pctoledo »
Is there any preview to implement this?
Toledo
Clipper On Line
Yes. Now I am working on VirtualGrid. It is nearing completion.
Let me try this after.
l3whmg
Post by l3whmg »
Hi guys,
when I start to understand class... it was to understand HMG4... :mrgreen:
Now, I write my little/personal version about HMG4 core and I find solution for enter on a textbox. I've modified some HMG4 source and this is the code.
The solution (my solution) is to specialize the "keyoard event" for any control/widget.
Anyway, I give my solution with HMG4
source name control.prg
I do some modification
METHOD OnEnter( bOnEnter ) CLASS CONTROL
   IF ::lCreated
      IF PCOUNT() == 0
         RETURN ::bOnEnter
      ELSEIF HB_ISBLOCK( bOnEnter ) == .T.
         ::bOnEnter := bOnEnter
      IF PCOUNT() == 0
         RETURN ::bOnEnter
source name textbox.prg
Added this method
   METHOD DoKeyBoardEvents
Connect DoKeyBoardEvents (near line 570)
   IF !::lGridCellFlag
* FOR KeyBoardEventProcessing...
 ::oQTObject:Connect( QEvent_KeyPress , {|e| Self:DoKeyBoardEvents( e )} )
      IF ValType( ::lVisible )      != 'U'   ; Self:Visible      := ::lVisible      ; ELSE   ; ::oQTObject:show()   ; ENDIF
Code of KeyBoardEvents method
METHOD TEXTBOX:DoKeyBoardEvents( e )
 LOCAL oKeyEvent := QKeyEventFromPointer( e )
 LOCAL nKey := oKeyEvent:key()
 LOCAL nModifiers := oKeyEvent:modifiers()
 HB_SYMBOL_UNUSED( nModifiers )
 IF nKey == Qt_Key_Return .OR. nKey == Qt_Key_Enter
  IF HB_ISBLOCK ( ::bOnEnter )
   EVAL( ::bOnEnter )
   RETURN .T.
RETURN ::oQTObject:Event( oKeyEvent )
Now You can use
DEFINE TEXTBOX name
 ROW ....
 COL....
 VALUE "sdisdui"
 ONENTER {|| OnEnterFunction() }
END TEXTBOX
Best regards to everyone.
Luigi from Italy
www.L3W.it
pctoledo
Post by pctoledo »
Hi Luigi,
Thanks for the help ... I'll do a test.
Toledo
Clipper On Line
Hazael
Post by Hazael »
rathinagiri wrote:Yes. Now I am working on VirtualGrid. It is nearing completion.
Hello,
Do you plan to implement it in HMG 3 too?
I think HMG 4 is interesting but I really like HMG 3
Thanks
Olá caro Toledo,
Tem conseguido solução para o evento ENTER apresentada pelo Luigi ?
Vou intentar ajudá-lo, apesar de não ser o meu forte métodos/POO.
Hi dear Toledo,
Have you found a solution for the event ENTER presented by Luigi ?
I'll try to help you, even I am not dominate methods / OOP.
B.Rgds
Note: I miss the staff of HMG4 ... :cry:
pctoledo
Post by pctoledo »
Olá Pablo, sim consegui usar a solução apresentada pelo Luigi, até desenvolvi um pequeno programa (incompleto) para testar as funções da HMG4, mas acabei abandonando o programa.
Link para demo:
http://www.pctoledo.com.br/forum/download/smew.zip
Usuário e Senha pode digitar qualquer coisa, não estou validando. Depois, veja Cadastro / Alunos / Inclusão.
Como é apenas um teste, o formulário de Inclusão não está gravando nada em banco de dados.
Hi Pablo, yes I used the solution presented by Luigi, I developed a small program (incomplete) to test the functions of HMG4 but just abandoning the program.
Link to demo:
User (Usuário) and Password (Senha) can type anything, I am not validating. Then see Cadastro / Alunos / Inclusão.
As it is only a test, the form of Inclusão is not writing anything in database.
Toledo
Clipper On Line
Gracias por compartir PCToledo !!!!
