Undefined function: sqlite3_open
karweru
DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Post by karweru »
Hi Friends,
I'm encountering the error above when my program executes the this line:
do("sqlite3_open", "accounts.db",.t.)
The purpose of calling sqlite3_open() this way is because i need to use NetIo RPC so that I can work on an sqlite database located on a remote pc.
I would greatly appreciate any help.
Kind regards,
Gilbert.
Re: Undefined function: sqlite3_open
It is working for me fine. What could be the problem then? Any file permission issues?
karweru
Post by karweru »
Hi Rathi,
Thanks for your time and effort. I'm also confused. When i run the following sample
#include 'minigui.ch'
#include 'hbclass.ch'
FUNCTION MAIN()
DEFINE WINDOW Form_1 ;
WIDTH 400 ;
HEIGHT 200 ;
TITLE 'RPC Test' ;
MAIN
DEFINE MAIN MENU
POPUP 'Test'
ITEM 'TEST RPC (1)' ACTION {||do("sqlite3_open","orgs.db",.t.)}
ITEM 'TEST RPC (2)' ACTION {||sqlite3_open("orgs.db",.t.)}
END POPUP
END MENU
CENTER WINDOW Form_1
ACTIVATE WINDOW Form_1
It runs without a problem, which means also I don't have access rights issues.
However, when i remark out the line
the undefined function : sqlite3_open error comes up.
I would appreciate any insights you might have. Thank you so much again for your time.
Kind regards,
Gilbert.
Hello Gilbert,
I also don't have any problem with that function. Following code is working fine.
   mRootDb := sqlite3_open(cRootDatabase, .t.)
   if mRootDb == nil
   	msgbox("Cannot Open/Create "+cRootDatabase)
   	return nil
Which version of HMG are you using?
I am using HMG 3.0.35. With HMG IDE, I don't need to add Sqlite library. You may also try with adding the library libhbsqlit3.a, from \HMG\HARBOUR\LIB
Thanks.
karweru
Post by karweru »
Hi Sudip,
Thanks for your response. I'm actually lost as to what the problem could be. I'm using the HMG version 3.0.35 (2010.06.20). I've 'resolved' the problem by including the dummy function below, which, though not called from anywhere in my program, seems to take out the problem.
FUNCTION force_sqlite_link()
sqlite3_open()
sqlite3_exec()
sqlite3_get_table()
sqlite3_prepare()
sqlite3_column_count()
sqlite3_column_decltype()
sqlite3_reset()
sqlite3_column_name()
sqlite3_errmsg()
sqlite3_errcode()
return
I've offloaded all minigui installations and even harbour and re-installed but to no avail. At this point, I have to believe the problem is with my environment, due to the fact that you and Rathi can't replicate the problem.
However, I'm grateful for your support.
Kind regards,
Gilbert.
