help me! About fonts for Vietnamese
nguyenchiduc
Post by nguyenchiduc »
Hello everyone
As introduced ...
My name is Nguyen Chi Duc, I come from Vietnam. I am 34 years old.
Exactly my name in Vietnam is "Nguyễn Chí Đức". Capitalization is "NGUYỄN CHÍ ĐỨC".
I checked most of the examples of HMG and I found very interesting. Many of them fit my work is done. The Vietnamese fonts display for the button, textbox, lablel, browse, gird ... is very good.
But there is a command "EDIT EXTEND" no font option.
"UNICODE" in HMG cause errors when displaying fonts in Vietnamese.
I switch characters became no letters in English. For example: The first records of the Customer Name
ĐỖ BÁ HOÀN => DO BA HOAN
Re: help me! About fonts for Vietnamese
First of all, HMG is not unicode ready. Regarding edit extended I will go through the source code.
nguyenchiduc
rathinagiri wrote:First of all, HMG is not unicode ready. Regarding edit extended I will go through the source code.
I checked Report, Grid, Browse can choose font, so it works well.
But EDIT and EDIT EXTEND no font options.
I used fonts ".vntime" for lowercase and ".vntimeh" for uppercase
nguyenchiduc
Another way of displaying font Vietnam
Hello everyone
I can open a file .dbf
Not declare parameters HEADERS, WIDTHS, COLUMNCONTROLS, COLUMNFIELDS in GRID
I use '. Vntime' to show the Vietnamese font
File: c:\temp\data.dbf
Here are the commands of the program:
#include "Dbinfo.ch"
#include "Dbstruct.ch"
  LOCAL header := {}, field := {}, width := {}, control := {}, i := 0
  REQUEST DBFCDX
  USE c:\temp\data.dbf alias data SHARED NEW via "DBFCDX"
  FOR i := 1 to FCOUNT()
      AADD(header , FIELDNAME(i))
      AADD(field , FIELDNAME(i))
      AADD(width , DBFIELDINFO(DBS_LEN,i)*10)
      DO CASE
      CASE DBFIELDINFO(DBS_TYPE,i) == "C"
          AADD(control,{"TEXTBOX","CHARACTER"})
      CASE DBFIELDINFO(DBS_TYPE,i) == "N"
          AADD(control,{"TEXTBOX","NUMERIC"})
      CASE DBFIELDINFO(DBS_TYPE,i) == "D"
          AADD(control,{"TEXTBOX","DATE"})
      ENDCASE
  DEFINE WINDOW Main AT 0,0 WIDTH 800 HEIGHT 600 MAIN ;
      ON RELEASE Closetable() ;
      FONT '.vntime' SIZE 11
     @ 10,10 GRID data_view WIDTH 770 HEIGHT 400 ROWSOURCE 'data' ;
     HEADERS header WIDTHS width COLUMNCONTROLS control COLUMNFIELDS field
  CENTER WINDOW Main
  ACTIVATE WINDOW Main
FUNCTION Closetable()
       close all
nguyenchiduc
Finally, I have found a way.
In the file: "C:\HMG\SOURCE\EDITEX\h_edit_ex.prg" and "C:\hmg\SOURCE\EDIT\h_edit.prg"
I replaced the phrase "ms sans serif" or "Arial" or "COURIER NEW" to =>".Vntime" or ".Vntimeh"
Then run the bat command : MAKELIB
Hopefully, if you encounter any similar cases can be solved this way.
Thank you
