i have some trobles with Harbour Mini Gui
Re: i have some trobles with Harbour Mini Gui
post fragment of your code, maybe someone can help you...
mol wrote:post fragment of your code, maybe someone can help you...
I sent you e-mail with solve of your problem... Does it works?
rpiccioli
Post by rpiccioli »
Oh My God ..
Yes, It works... thank you a lot ...
I read that line a lot of times...
I'm ashamed..
Thank you mol !!!!
Riccardo Piccioli
My pleasure....
Sometimes I look for error for long time and can't find it.
The worst errors are stupid...
regards, Marek
rpiccioli
Post by rpiccioli »
mol wrote:My pleasure....
regards, Marek
What is the difference in DEFINE WINDOWS between MAIN And Modal?
Because i tryed to adapt a code th stand alone seems to work
Procedure PBro_Corsi()
	SET CENTURY ON
	SET DELETED ON
       DEFINE WINDOW bro_corsi ;
		WIDTH 1024 HEIGHT 580 ;
		TITLE '1000 Bolle Blu - Browse Corsi' ;
		MAIN NOMAXIMIZE ;
		ON INIT OpenCorsi() ;
		ON RELEASE CloseCorsi();
... but inside the main code give me the following error running the program:
Main window already defined. Program terminated.
Of course I have my main window at beginning, but if i write MODAL in place of MAIN NOMAXRESIZE che compiler gives me error in ON INIT statement.
So, i'm just asking: If i write a file called browse.prg for example ... can i link it on the main menu? in this case i think not to have problems with MAIN statement. How can i call another prg file from the main one?
Riccardo Piccioli
Yes. It is because, MODAL windows don't have NO MAXIMIZE option. :)
This is the syntax for MODAL windows:
DEFINE WINDOW <WindowName>
		AT <nRow> ,<nCol>
		WIDTH <nWindth>
		HEIGHT <nHeight>
		[ VIRTUAL WIDTH <nVirtualWindth> ]
		[ VIRTUAL HEIGHT <nVirtualHeight> ]
		[ TITLE <cTitle> ]
		[ ICON <cIconName> ]
		MODAL
		[ NOSHOW ]
		[ NOAUTORELEASE ]
		[ NOSIZE ]
		[ NOSYSMENU ]
		[ NOCAPTION ]
		[ CURSOR <CursorName> ]
		[ ON INIT <InitProcedureName> | <bBlock> ]
		[ ON RELEASE <ReleaseProcedureName> | <bBlock> ]
		[ ON INTERACTIVECLOSE <InteractiveCloseProcedureName> | <bBlock> ]
		[ ON MOUSECLICK <MouseClickProcedureName>  | <bBlock> ]
		[ ON MOUSEDRAG <MouseDragProcedureName>  | <bBlock> ]
		[ ON MOUSEMOVE <MouseMoveProcedureName>  | <bBlock> ]
		[ ON SIZE <WindowSizeProcedureName>  | <bBlock> ]
		[ ON PAINT <WindowPaintProcedureName>  | <bBlock> ]
		[ BACKCOLOR <anBackColor> ]
		[ FONT <cFontName> SIZE <nFontSize> ]
		[ ON GOTFOCUS <ProcedureName> | <bBlock> ]
		[ ON LOSTFOCUS <ProcedureName> | <bBlock> ]
		[ ON SCROLLUP <ProcedureName> | <bBlock> ]
		[ ON SCROLLDOWN <ProcedureName> | <bBlock> ]
		[ ON SCROLLLEFT <ProcedureName> | <bBlock> ]
		[ ON SCROLLRIGHT <ProcedureName> | <bBlock> ]
		[ ON HSCROLLBOX <ProcedureName> | <bBlock> ]
		[ ON VSCROLLBOX <ProcedureName> | <bBlock> ]
		[ HELPBUTTON ]
This can be done through two ways.
If you use MiniGUI IDE to maintain your project, it will be enough if you just add the browse.prg in your project as a module. This program will also be compiled and linked along with the main prg file.
If you use batch file (compile.bat) from command prompt, then you can refer the browse.prg in your main.prg as "set procedure to browse.prg" to include browse.prg also while compiling.
rpiccioli
Post by rpiccioli »
At the beginning under che include statement? Or i have to declare on an Action statement?
At the moment, in browse.prg i defined:
Function MAIN
	SET CENTURY ON
	SET DELETED ON
and if i compile the file as standalone it works.
But with instruction
and writing in browse.prg :
Function f_brocorsi
SET CENTURY ON
SET DELETED ON
	MAIN NOMAXIMIZE ;
CENTER WINDOW bro_corsi
bro_corsi.Bbro_corsi.SetFocus()
ACTIVATE WINDOW bro_corsi
gives me the same error than before:
Main window Alaready defined. Program Terminated
Thank you rathinagiri.
Riccardo Piccioli
Yes. That is because MODAL windows have no option for NOMAXIMIZE. You can only have NOSIZE.
rpiccioli
Post by rpiccioli »
rathinagiri wrote:Yes. That is because MODAL windows have no option for NOMAXIMIZE. You can only have NOSIZE.
so I have to put the window in browse.prg as modal.
Ok...
Thank you
Riccardo Piccioli
