Hello everyone:
This is the first I work with print system. Attachment is my coding block. I put MsgInfo() where I would to check if program go through or not. The answer is yes. But nothing display on the screen at al even if I set PREVIEW. Where did I go wrong?
Please Help!
Best Regrads.
chen min
Nothing displayed on sceen even PREVIEW was setup!
huangchenmin
- DM_EDUACT.zip
- (32.03 KiB) Downloaded 199 times
Re: Nothing displayed on sceen even PREVIEW was setup!
You have to select the printer first!
Kindly see /hmg/samples/print folder.
select printer default preview
or
select printer cPrinterName preview
or
select printer dialog
huangchenmin
Sorry guy!rathinagiri wrote:Hi,
It's all my fault!
It's all because an unbalance START PRINTDOC.
Best Regards
chen min
