Grid control & Numerics
karweru
DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Post by karweru »
Hello group,
I have modified grid07 sample to illustrate a problem I'm having. Appararently, grid control is not showing numeric values or what could be the issue here?
Kindly assist.
demo.zip
(1.33 KiB) Downloaded 247 times
Kind regards,
Gilbert.
Re: Grid control & Numerics
karweru wrote:Hello group,
Kindly assist.
Hello Gilbert,
Kindly try the following updated sample: :arrow:
#include "minigui.ch"
Local aRows [20] [3]
Public Op
	aRows [1]	:= {'Simpson','Homer',10000}
	aRows [2]	:= {'Mulder','Fox',40000}
	aRows [3]	:= {'Smart','Max',30000}
	aRows [4]	:= {'Grillo','Pepe',20000}
	aRows [5]	:= {'Kirk','James',5000}
	aRows [6]	:= {'Barriga','Carlos',2000}
	aRows [7]	:= {'Flanders','Ned',100}
	aRows [8]	:= {'Smith','John',25000}
	aRows [9]	:= {'Pedemonti','Flavio',50000}
	aRows [10]	:= {'Gomez','Juan',8000}
	aRows [11]	:= {'Fernandez','Raul',13000}
	aRows [12]	:= {'Borges','Javier',18000}
	aRows [13]	:= {'Alvarez','Alberto',22000}
	aRows [14]	:= {'Gonzalez','Ambo',40000}
	aRows [15]	:= {'Batistuta','Gol',3500}
	aRows [16]	:= {'Vinazzi','Amigo',4500}
	aRows [17]	:= {'Pedemonti','Flavio',7500}
	aRows [18]	:= {'Samarbide','Armando',90000}
	aRows [19]	:= {'Pradon','Alejandra',1000000}
	aRows [20]	:= {'Reyes','Monica',4000000}
	aCtrl_1 := {'TEXTBOX','CHARACTER'}
	aCtrl_2 := {'TEXTBOX','CHARACTER'}
	aCtrl_3 := {'TEXTBOX','NUMERIC','9999999999'}
	DEFINE WINDOW Form_1 ;
		WIDTH 630 ;
		HEIGHT 480 ;
		TITLE 'Hello World!' ;
		MAIN ;
		FONT 'Arial' ;
		SIZE 9
		DEFINE LABEL Label_1
			ROW	10
			COL	10
			WIDTH	60
			VALUE 'Apellido:'
		END LABEL
		DEFINE TEXTBOX Text_1
			ROW	10
			COL	70
			WIDTH	80
		END TEXTBOX
		DEFINE LABEL Label_2
			ROW	10
			COL	160
			WIDTH	60
			VALUE	'Nombres:'
		END LABEL
		DEFINE TEXTBOX Text_2
			ROW	10
			COL	230
			WIDTH	80
		END TEXTBOX
		DEFINE LABEL Label_3
			ROW	10
			COL	320
			WIDTH	60
			VALUE	'Balance:'
		END LABEL
		DEFINE TEXTBOX Text_3
			ROW	10
			COL	390
			WIDTH	80
			NUMERIC .T.
		END TEXTBOX
		DEFINE BUTTON Button_A
			ROW	10
			COL	480
			WIDTH	55
			CAPTION	'Ok'
			ACTION	Ok()
		END BUTTON
		DEFINE BUTTON Button_B
			ROW	10
			COL	545
			WIDTH	55
			CAPTION	'Cancel'
			ACTION	Cancel()
		END BUTTON
		DEFINE GRID Grid_1
			ROW 	40
			COL	10
			WIDTH	590
			HEIGHT	330
			HEADERS	{ 'Apellido' , 'Nombres' , 'Balance' }
			WIDTHS	{ 185 , 185 , 185 }
			ITEMS	aRows
			COLUMNCONTROLS { aCtrl_1 , aCtrl_2 , aCtrl_3 }
			JUSTIFY { GRID_JTFY_LEFT, GRID_JTFY_LEFT, GRID_JTFY_RIGHT }
			VALUE	1
		END GRID
		DEFINE BUTTON Button_1
			ROW	380
			COL	10
			CAPTION	'Agregar'
			ACTION	Agregar()
		END BUTTON
		DEFINE BUTTON Button_2
			ROW	380
			COL	140
			CAPTION	'Eliminar'
			ACTION	Eliminar()
		END BUTTON
		DEFINE BUTTON Button_3
			ROW	380
			COL	270
			CAPTION	'Modificar'
			ACTION	Modificar()
		END BUTTON
	Form_1.Text_1.Enabled :=.f.
	Form_1.Text_2.Enabled :=.f.
	Form_1.Text_3.Enabled :=.f.
	Form_1.Button_A.Enabled :=.f.
	Form_1.Button_B.Enabled :=.f.
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Procedure Agregar()
	Op := 'AGREGAR'
	Form_1.Text_1.Enabled :=.t.
	Form_1.Text_2.Enabled :=.t.
	Form_1.Text_3.Enabled :=.t.
	Form_1.Button_1.Enabled :=.f.
	Form_1.Button_2.Enabled :=.f.
	Form_1.Button_3.Enabled :=.f.
	Form_1.Button_A.Enabled :=.t.
	Form_1.Button_B.Enabled :=.t.
	Form_1.Grid_1.Enabled := .f.
	Form_1.Text_1.SetFocus
Procedure Eliminar()
Local i := Form_1.Grid_1.Value
	If i != 0
		Form_1.Grid_1.DeleteItem(i)
	EndIf
Procedure Modificar()
Local i := Form_1.Grid_1.Value , aTemp
	Op := 'MODIFICAR'
	If i != 0
		aTemp := Form_1.Grid_1.Item(i)
		Form_1.Text_1.Value := aTemp [1]
		Form_1.Text_2.Value := aTemp [2]
		Form_1.Text_3.Value := aTemp [3]
	EndIf
Procedure Ok()
Local aTemp := {} , i
	If	Op == 'AGREGAR'
		Form_1.Grid_1.AddItem ( { Form_1.Text_1.Value , Form_1.Text_2.Value , Form_1.Text_3.Value } )
		Form_1.Grid_1.Value := Form_1.Grid_1.ItemCount
	ElseIf	Op == 'MODIFICAR'
		Form_1.Grid_1.Item (i) := { Form_1.Text_1.Value,Form_1.Text_2.Value ,Form_1.Text_3.Value }
	EndIf
	Form_1.Text_1.Value := ''
	Form_1.Text_2.Value := ''
	Form_1.Text_3.Value := ''
	Form_1.Button_1.Enabled :=.t.
	Form_1.Button_2.Enabled :=.t.
	Form_1.Button_3.Enabled :=.t.
	Form_1.Grid_1.Enabled := .t.
	Form_1.Grid_1.SetFocus
Procedure Cancel()
Hope that helps :idea:
karweru
Post by karweru »
Thank you very much Grigory for you quick attention. Now the numerics are displaying properly. The problem now is when you edit a record. I'm getting the following error when i run your modified sample.
Date:10/12/10 Time: 10:01:45
Error BASE/1090 Argument error: INT
Called from INT(0)
Called from _SETVALUE(487)
Called from SETPROPERTY(6441)
Called from MODIFICAR(188)
Called from (b)MAIN(129)
Called from _DOCONTROLEVENTPROCEDURE(5262)
Called from EVENTS(1434)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4853)
Called from MAIN(143)
Any way around this? Thanks again for your help.
Kind regards,
Gilbert.
karweru wrote:Thank you very much Grigory for you quick attention. Now the numerics are displaying properly. The problem now is when you edit a record. I'm getting the following error when i run your modified sample.
Gilbert,
Try the following working sample: :arrow:
Public Op
      WIDTH 630 ;
      HEIGHT 480 ;
      MAIN ;
      FONT 'Arial' ;
      SIZE 9
         ROW   10
         COL   10
         WIDTH   60
         VALUE 'Apellido:'
      END LABEL
         ROW   10
         COL   70
         WIDTH   80
      END TEXTBOX
         ROW   10
         COL   160
         WIDTH   60
         VALUE   'Nombres:'
      END LABEL
         ROW   10
         COL   230
         WIDTH   80
      END TEXTBOX
         ROW   10
         COL   320
         WIDTH   60
         VALUE   'Balance:'
      END LABEL
         ROW   10
         COL   390
         WIDTH   80
         NUMERIC .T.
      END TEXTBOX
         ROW   10
         COL   480
         WIDTH   55
         CAPTION   'Ok'
         ACTION   Ok()
      END BUTTON
         ROW   10
         COL   545
         WIDTH   55
         CAPTION   'Cancel'
         ACTION   Cancel()
      END BUTTON
      DEFINE GRID Grid_1
         ROW    40
         COL   10
         WIDTH   590
         HEIGHT   330
         ITEMS   aRows
         VALUE   1
      END GRID
         ROW   380
         COL   10
         CAPTION   'Agregar'
         ACTION   Agregar()
      END BUTTON
         ROW   380
         COL   140
         CAPTION   'Eliminar'
         ACTION   Eliminar()
      END BUTTON
         ROW   380
         COL   270
         CAPTION   'Modificar'
         ACTION   Modificar()
      END BUTTON
Procedure Agregar()
   Op := 'AGREGAR'
   If i != 0
   EndIf
   Op := 'MODIFICAR'
   If i != 0
   EndIf
Procedure Ok()
   If   Op == 'AGREGAR'
   EndIf
   Form_1.Text_3.Value := 0
Procedure Cancel()
karweru
Post by karweru »
Thank you so much Grigory. It works perfectly now. Warm regards,
Kind regards,
Gilbert.
