HMG IDE
cocoking
HMG IDE
Post by cocoking »
How do I use the IDE for existing programs?
Forms were designed using .prg (using DEFINE) but I find counting pixels too tedious. So I'd like to use the IDE to design the GUI part but would also like to continue using my text editor for the non-GUI part.
Is this possible?
Re: HMG IDE
Yes. It is.
The form generator creates a file with extension .fmg. Which is again a .prg file. You can open with a text editor and replace the template with your window name and paste the code in your test editor wherever necessary.
cocoking
Re: HMG IDE
Post by cocoking »
Thanks, Rathi. Please allow me additional questions.
1. How do I create the main menu (pop up with items) in HMG IDE? I can't seem to display it in the form.
2. Is it possible to specify the location of a modal window to be relative to the main form? That is, if (before calling the modal window) the main form is moved, the modal window also adjusts?
3. I'm using a screen ruler (MWSnap/FastStone Capture) to position objects. Is there a better way (aside from HMG IDE, of course)?
I hope somebody finds time to write a user's manual (as opposed to reference manual) for HMG and HMG IDE. It complements the reference manual. It would be a very big help for newbies like me.
With the forum, while very informative and helpful, it is just too easy to miss information, resulting sometimes in repetitive questions. Just a suggestion though, I hope I'm not being too demanding. On the contrary, it will also save the time of Rathi, Sudip, Marek and Esgici (who've been very helpful even with beginners' questions).
Re: HMG IDE
Hi cocoking
Some hints for HMG IDE
Please look at attached image; I hope that it have an answer to your question. IDE include "builders", no for only main menu, for other type menus too.
Auto-adjusting discussed in the forum in various manners. Please use search.
I haven't any idea about tools you are talking about. But HMG-IDE has two perfect features for tracking screen coordinates: coordinates and size of current control and current cursor position. Please look at attached image.
Documentation too discussed for various aspects. In summary, IMHO, HMG reference manual is a perfect source and except for a few conditions it's unnecessary a separate user's manual. More important, HMG is a very dynamic project; everything changes with extremely high speed, so almost every reference source will become stale quickly. Please take a look to very beginning topics (beginning with What is MiniGUI?, continuing with Quick Start and Simple Tutorial 1..17 ) of HMG General Help forum; simply to HMG Oficial Help. I hope that all this information is sufficient for newbies.
In other hand HMG Doc also include a little but helpful section for IDE:
IDE Section of HMG Doc
Please don't worry about demanding. Persons who respond you was newbies too for a short time ago ;)
cocoking
Re: HMG IDE
Post by cocoking »
TYVM, Esgici. I can really feel your genuine desire to help and your diligence.
Actually, I have used the main menu builder, filled up the Caption and Name for several menu items. But when I clicked Ok, the menu did not appear on the form. What do I need to do next?
Yes, the ruler function is built into HMG IDE but I can also use the screen rulers over running program windows. Actually, I was forced to use the screen ruler because I did not know how to use the IDE (ie, can't even make a menu). Notepad ++ as text editor + MWSnap to count screen coordinates, that's how I made my program. As soon as I know HMG IDE, I may no longer have use for screen rulers.
Thanks also for the "help" hints.
