I am getting errors after install new binaries hmg.4
jparada
Post by jparada »
After uninstalling the old version of hmg.4 and install the new version (hmg.4 Win ver.2010.09.02).
I am getting many errors like this:
c: / hmg.4/harbour/lib/win/mingw/libhbqtcore.a (QUrl.o): QUrl.cpp: (. text +0 xb03): und
efine reference to `_Unwind_SjLj_Unregister '
c: / hmg.4/harbour/lib/win/mingw/libhbqtcore.a (QUrl.o): QUrl.cpp: (. text +0 xb30): und
efine reference to `_Unwind_SjLj_Resume '
c: / hmg.4/harbour/lib/win/mingw/libhbqtcore.a (QUrl.o): QUrl.cpp: (. xb4a text +0): und
efine reference to `__gxx_personality_sj0 '
c: / hmg.4/harbour/lib/win/mingw/libhbqtcore.a (QUrl.o): QUrl.cpp: (. text +0 xb73): und
efine reference to `_Unwind_SjLj_Register '
Any help please?.
Thanks.
PS. Before, with the previous version worked well.
Best Regards
Javier
Re: I am getting errors after install new binaries hmg.4
jparada wrote:Hi,
Any help please?.
Thanks.
Best Regards
Javier
Please, try manually removing all the content of your previous installations and reinstalling again.
jparada
Post by jparada »
Hi Roberto,
Thanks for answering,
After doing what you advised me, I again had the same problem, then what I did was, just to set my path hmg4 environment (ie hmg4, hmg4/qt/bin, hmg4/harbour/bin) and it worked well.
I have the qt version 4.6.2 in my path, this might cause problems?.
As I said before everything was working fine until I install the new binaries hmg4 (previously I had no problems, even with my version of qt in my path)
Thanks
Best Regards
Javier
jparada wrote: I have the qt version 4.6.2 in my path, this might cause problems?.
Yes. That could be the problem. HMG.4 is based on 4.5.3
You do not need to install QT.
All needed things are in \hmg.4.
