Hola!
Alguien me puede dar una ayuda con esto? La idea sería escanear una imagen (fotografia) y almacenarla en un campo del paciente - socio - cliente. Luego al consultar la BD se podria hacer un preview de esa imagen?
Con los otros ejemplos que hay en el foro, aprendí mucho en estos días.
Gracias y perdonen si es una pregunta inadecuada.
---------------google------
Hello!
Can anybody give me a help with this? The idea would be to scan an image (photography) and to store it in a field of the patient - associate - client. Then on having consulted the BD, might do a preview of this image?
With other examples that exist in the forum, I learned very much in these days.
Thank you and excuse if it is an inadequate question.
Tep
How to store an image in SQLITE with HMG?
Re: How to store an image in SQLITE with HMG?
I think the simple way is to save a field of path of image filenames and keeping all the images in a particular folder.
Other way around is to convert our image data into text (may be we can use MIME here) and back from text to data. Please keep in mind that, if the number of rows of the database is huge, the database will be very big.
Both the methods have pros and cons.
Non testes from Harbour tree:
HTH
Angel
* SQLite3 Demo
* Copyright 2007 P.Chornyj <myorg63@mail.ru>
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2, or (at your option)
* any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this software; see the file COPYING. If not, write to
* the Free Software Foundation, Inc., 59 Temple Place, Suite 330,
* Boston, MA 02111-1307 USA (or visit the web site http://www.gnu.org/).
* As a special exception, the Harbour Project gives permission for
* additional uses of the text contained in its release of Harbour.
* The exception is that, if you link the Harbour libraries with other
* files to produce an executable, this does not by itself cause the
* resulting executable to be covered by the GNU General Public License.
* Your use of that executable is in no way restricted on account of
* linking the Harbour library code into it.
* This exception does not however invalidate any other reasons why
* the executable file might be covered by the GNU General Public License.
* This exception applies only to the code released by the Harbour
* Project under the name Harbour. If you copy code from other
* Harbour Project or Free Software Foundation releases into a copy of
* Harbour, as the General Public License permits, the exception does
* not apply to the code that you add in this way. To avoid misleading
* anyone as to the status of such modified files, you must delete
* this exception notice from them.
* If you write modifications of your own for Harbour, it is your choice
* whether to permit this exception to apply to your modifications.
* If you do not wish that, delete this exception notice.
* See COPYING for licensing terms.
#include "hbsqlit3.ch"
#define TABLE_SQL "CREATE TABLE image( id INTEGER PRIMARY KEY AUTOINCREMENT, title TEXT(50), image BLOB )"
PROCEDURE main()
LOCAL lCreateIfNotExist := .t.
LOCAL db := sqlite3_open( "test.s3db", lCreateIfNotExist )
LOCAL stmt
LOCAL buff, blob
IF ! Empty( db )
sqlite3_exec( db, "PRAGMA auto_vacuum=0" )
sqlite3_exec( db, "PRAGMA page_size=8192" )
sqlite3_exec( db, "DROP TABLE image" )
sqlite3_exec( db, TABLE_SQL )
stmt := sqlite3_prepare( db, "INSERT INTO image( title, image ) VALUES( :title, :image )")
IF ! Empty( stmt )
buff := sqlite3_file_to_buff( "pngtest.png" )
IF sqlite3_bind_text( stmt, 1, "pngtest.png" ) == SQLITE_OK .AND. ;
sqlite3_bind_blob( stmt, 2, @buff ) == SQLITE_OK
IF sqlite3_step( stmt ) == SQLITE_DONE
?"Save pngtest.png into BLOB"
? "INSERT INTO image( title, image ) VALUES( 'pngtest.png', 'pngtest.png' ) - Done"
buff := NIL
sqlite3_clear_bindings( stmt )
sqlite3_finalize( stmt )
? "The number of database rows that were changed: " + ltrim( str( sqlite3_changes( db ) ) )
? "Total changes: " + ltrim( str( sqlite3_total_changes( db ) ) )
sqlite3_sleep( 3000 )
blob := sqlite3_blob_open( db, NIL, "image", "image", sqlite3_last_insert_rowid( db ), 0 /* 0 - RO; 1- RW */ )
IF !Empty( blob )
? "Open BLOB image - Ok"
buff := sqlite3_blob_read( blob )
/* Call sqlite3_blob_bytes() only after sqlite3_blob_read() */
? "The size in bytes of the blob - ", sqlite3_blob_bytes( blob )
IF ( sqlite3_buff_to_file( "pngtest1.png", @buff ) == SQLITE_OK )
? "Save BLOB into pngtest1.png - Done"
buff := NIL
sqlite3_blob_close( blob )
? "Close BLOB"
?"Save BLOB using sqlite3_column_blob()"
stmt := sqlite3_prepare( db, "SELECT image FROM image WHERE id == ?5 ")
IF !Empty( stmt )
IF sqlite3_bind_int64( stmt, 5, sqlite3_last_insert_rowid( db ) ) == SQLITE_OK
IF sqlite3_step( stmt ) == SQLITE_ROW
buff := sqlite3_column_blob( stmt, 1 )
IF ( sqlite3_buff_to_file( "pngtest2.png", @buff ) == SQLITE_OK )
? "Save BLOB into pngtest2.png - Done"
buff := NIL
wait
Angel
Angel Pais
I liked the idea of rathinagiri. I will prove it and I will comment on you to them.
Thanks for his suggestions!
Me gustó la idea de rathinagiri. La probaré y les comentaré .
Gracias por sus sugerencias!
Slds
Slds
