HMG IDE - Multiple controls select on form etc ...
Hi ... possibly 'Hi Roberto'
In years gone by I did extensive development using MS Visual Fox Pro.
One thing I am severely missing in HMG IDE is the ability to select and move groups of controls, which means that currently it comes down to a laborious exercize of selecting each control individually, then moving/adjusting/aligning, and finally deciding whether another layout might be more suitable - at which point the whole process starts all over again ... sometimes I've simply had to use a text editor to get the job done faster.
Don't get me wrong, I sure enjoy the whole HMG + HMG-IDE thing. It's just that getting things done fast/faster is crucial to cost effective development.
Apart from that I am a big HMG/HMG-IDE fan!
Cheers,
Frank E.
Cheers,
Frank E.
- HMG Founder
Re: HMG IDE - Multiple controls select on form etc ...
I've stopped all coding based on Windows API.FrankE wrote:Hi ... possibly 'Hi Roberto'
Cheers,
Frank E.
HMG 3.0.x and its IDE are in maintenance (bug fixing only).
HMG.4 (QT based) hopefully will have its own new open source IDE.
The first goal for this project will be to mimic the current IDE behavior and to be extended later.
That's great Roberto.HMG.4 (QT based) hopefully will have its own new open source IDE.
- HMG Founder
We'll be able to start when most important controls reach a reasonable degree of completion.rathinagiri wrote:That's great Roberto.HMG.4 (QT based) hopefully will have its own new open source IDE.
Anyway, we will must use plain QT for low level things, such as form editor.
WowRoberto Lopez wrote: ...
since this is possible (without programing in C) that QT is really big thing
Best regards
- Czarny_Pijar
Please check this topic http://hmgforum.com/viewtopic.php?f=6&t=1563,FrankE wrote: One thing I am severely missing in HMG IDE is the ability to select and move groups of controls, which means that currently it comes down to a laborious exercize of selecting each control individually, then moving/adjusting/aligning, and finally deciding whether another layout might be more suitable - at which point the whole process starts all over again ... sometimes I've simply had to use a text editor to get the job done faster.
Frank E.
probably my freeware called fmg_tool_ver2.zip which you can find there, may be useful for you.
- HMG Founder
Very Nice!!!Czarny_Pijar wrote:Please check this topic http://hmgforum.com/viewtopic.php?f=6&t=1563,FrankE wrote: One thing I am severely missing in HMG IDE is the ability to select and move groups of controls, which means that currently it comes down to a laborious exercize of selecting each control individually, then moving/adjusting/aligning, and finally deciding whether another layout might be more suitable - at which point the whole process starts all over again ... sometimes I've simply had to use a text editor to get the job done faster.
Frank E.
This is an old desire to believe most like to see running as in other IDEs.
There is need to implement the IDE, you can allow multiple selections with fine adjustment in the positions of the components.
Here is a good example (see attached file pack) of handling components, but the events of mouse HMG as RightButton are not available (at least in internal form) which makes it difficult to implement this same example in HMG.
- ControlPos_3.rar
- (575 KiB) Downloaded 363 times
All our C guru can implement RightButton and for expert it not so big projectPablo César wrote: But the events of mouse HMG as RightButton are not available (at least in internal form) which makes it difficult to implement this same example in HMG.
I believe the real solution is based in internal variables which contains this can information, at leat I saw that in HMGS taht the variable _HMG_MouseState are declared in h_init and is updating in all mouse events (see C:\MiniGUI\SAMPLES\BASIC\Mouse_Coords\demo3.prg). I think is a structure conditions and probably there is a programmable solution.bpd2000 wrote:All our C guru can implement RightButton and for expert it not so big project
