HMG.4 Problems / Questions
Hi all
It's annoying being first in such topic :(
from C:\HMG.4\hmg\samples\window.main\demo_1.prg :
Error BASE/1004 No exported method: EVAL
Called from (b)EVAL(0)
Called from WINDOW:ACTIVATE(1829)
Called from MAIN(27)
Re: HMG.4 Problems
And ...
C:\HMG.4\hmg\samples\combobox\demo_1 :
Error BASE/1005 Message not found: COMBOBOX:_VALUE
Called from __ERRRT_SBASE(0)
Called from COMBOBOX:ERROR(0)
Called from (b)HBOBJECT(0)
Called from COMBOBOX:MSGNOTFOUND(0)
Called from COMBOBOX:_VALUE(0)
Called from MAIN(31
C:\HMG.4\hmg\samples\combobox\demo_2 :
Called from MAIN(28)
C:\HMG.4\hmg\samples\combobox\demo_3 :
Called from MAIN(30)
Re: HMG.4 Problems
Too many errors :(
Including compiler errors :(
Probably I miss somethings important :cry:
Re: HMG.4 Problems
Hola Esgici:
yo segui los pasos para bajar todo desde el SVN , compile siguiendo mis metodos
(ver http://hmgforum.com/viewtopic.php?f=24&t=1641 y no eh tenido problemas
no tengo la carpeta llamada HMG dentro de HMG4
un saludo
Re: HMG.4 Problems
esgici wrote:Hi all
The code was incorrectly changed.
It is currently:
:OnInit := oWindow:Center()
But it should be:
:OnInit := { || oWindow:Center() }
I'll correct it and commit the fix.
Re: HMG.4 Problems
esgici wrote:And ...
Called from MAIN(31
Combobox is not coded yet, so the sample is not working.
Re: HMG.4 Problems
All are about SVN :(
Some help of Daniel give me some hints :)
My and Daniel's dir stru is different :o
IMHO only mystic is SVN ;)
Sadly my battery discharged for today.
Best regards
Re: HMG.4 Problems
esgici wrote:All are about SVN :(
Best regards
I've uploaded a fix and removed samples for not started controls.
To assure that you have the correct installation, please, delete the content of SVN folder, go to explorer, right click on it and select 'SVN checkout'.
When finished, you'll have a clean and updated copy of the sources.
Re: HMG.4 Problems
Hello
Two different HMG.4 <DIR> structures
I'm still confusing :?
<DIR> was building by downloaded HMG.4 setup prg and changed by SVN :?
Which one is correct, and how I can reach that correct way ?
Re: HMG.4 Problems
... and,
struggling under these type of detailed problems make very fatigue me :cry:
