Page 1 of 3
A grid.cell problem
Posted: Thu Jul 29, 2010 2:03 pm
Hi all
I have a big (for me) problem came from this little prg
Error BASE/1068 Argument error: array access
Called from _HMG_GETGRIDCELLVALUE(1548)
Called from GETPROPERTY(7196)
Called from SHOWG2CELL(124)
Called from (b)MAIN(46)
Called from _DOCONTROLEVENTPROCEDURE(5262)
Called from _SETVALUE(577)
Called from _DEFINEGRID(487)
Called from MAIN(46)
Where I'm wrong, any opinion ?
- GridTest.rar
- For testing a grid.cell problem
- (1.6 KiB) Downloaded 243 times
Re: A grid.cell problem
Posted: Thu Jul 29, 2010 3:25 pm
by sudip
Hi Esgici,
It is because ShowG2Cell() is called before initialization.
Here is my quick and dirty solution
You may also try asigning value to grid_2 after END WINDOW
form_1.grid_2.value := {1, 1}
Posted: Thu Jul 29, 2010 3:53 pm
Hi Sudip
Thanks, but the .zip include only .hbp, not .prg
... and not solved adding line to after END WINDOW too
Posted: Thu Jul 29, 2010 4:08 pm
Sorry
Your trick prevent error for only first (initial) calling of ShowG2Cell()
Please try select any cell in Grid_2 after program run.
Posted: Thu Jul 29, 2010 4:23 pm
by sudip
Yes Esgici,
You are correct. I was wrong.
May be grid with table works differently than array grid.
Again my very dirty solution:
PROC ShowG2Cell()
aValue := This.Value
nRow := aValue[ 1 ]
nCol := aValue[ 2 ]
cContent := test->(fieldget(ncol)) //this.Cell( nRow, nCol )
MsgBox( cContent )
RETU // ShowG2Cell()
Posted: Thu Jul 29, 2010 4:46 pm
Yes, it's
Sadly, this is my principal problem : when changing row of grid, record of table doesn't change always
And I want understand when they are change and when not; and how I can setup a "synchronism" between rows of grid and records of table
Sudip wrote:May be grid with table works differently than array grid.
The sample has this two kind of grid for emphasize this point
All comment and suggestion are welcome
Posted: Thu Jul 29, 2010 5:51 pm
by mol
I've tried to resolve this problem, but any idea comes to my head. Maybe tomorrow the solution becomes. Sometimes you need to sleep with problem to resolve it.
Marek
Posted: Thu Jul 29, 2010 5:55 pm
mol wrote:I've tried to resolve this problem, but any idea comes to my head. Maybe tomorrow the solution becomes.
Thanks, I'll wait
Yes, if you can sleep together problem
Posted: Fri Jul 30, 2010 6:19 am
by mol
I was reading sources of HMG and It looks that internal table of GRID is not initialized when ROWSOURCE is declared. So you can not use phrase:
cContent := this.Cell( nRow, nCol )
to retrieve data from database driven grid.
I've modified a little your function. It was necessary to call _HMG_SysData table to retrieve some data.
PROC ShowG2Cell()
local i
local aValue, aColumnFields, cField
local cContent
local nRecNo
if lInitTime
return
nRow := aValue[ 1 ]
nCol := aValue[ 2 ]
i := GetControlIndex ( This.Name , ThisWindow.Name )
xSelect := _HMG_SYSDATA [ 40 ] [ i ] [ 10 ]
if valtype(xSelect) = "C"
// database driven grid
aColumnFields := _HMG_SYSDATA [ 40 ] [ i] [ 11 ]
nRecNo := GetProperty(ThisWindow.Name, This.Name, "RecNo")
goto nRecno
cField := aColumnFields[nCol]
cContent := &cField
MsgBox( cContent )
PS. Didn't I write you should asleep with problem?
Besides, I think it should be easier way to retrieve data from grid based on database, not table. It's next job for Roberto
Best regards, Marek
Posted: Fri Jul 30, 2010 8:36 am
Thanks a lot Marek, I'll try ...
I'm afraid I couldn't understand this point. What is difference database and table ?
