Billing system
Re: Billing system
Yes. This I have used in many projects. If a grid is focused and an user presses DEL key, I will delete the row. However, if he presses DEL key outside the grid, the normal operation will continue.
Re: Billing system
rathinagiri wrote:I too get this problem Esgici.
But I have avoided by using like this.
public lFocused := .f.
define window blah blah
   define grid blah
      row 10
      col 10
      on gotfocus lFocused := .t.
      on lostfocus lFocused := .f.
   end grid
   on key DOWN action doarrowaction()
end window
function doarrowaction
if lFocused
return nil
By this way, we can restrict the key usage to a single control.
very smart and interesting idea !
I'll try to implement it... It's easy because all buttons are defined in the loop, so few lines of code will be enough to realise it.
THX Rathi!
Re: Billing system
I've modified code, but ... Main menu doesn't take focus from other controls ... :(
So, this idea is not for use...
Maybe I'll find something different.
Best regards, Marek
Re: Billing system
I will try a small sample Marek.
Re: Billing system
Dear Marek
Interest to see Billing system source code
Re: Billing system
I've send you link in private message. So, happy testing!
Re: Billing system
Dear Marek
No word for your Excellant code
It is not code but, is BIBLE for me to learn somthing
Thank you for sharing your hard work
Re: Billing system
It's my pleasure to help you!
Best regards, Marek
Re: Billing system
I've made some changes in function displaying table of invoices. It's incredible, how relations can slow down the program in the network environment:
You can watch old version with relations and filter:
http://www.molsystemy.pl/hmg/1-stara-wersja.avi
and quick new version:
http://www.molsystemy.pl/hmg/2-nowa-wersja.avi
mrduck
Re: Billing system
Post by mrduck »
Hi Malek,
it would be nice to know which are the changes you did in the code :-)
Francesco
