Billing system
Re: Billing system
mol wrote: I've installed last version of DBA, but ca't find Floating Buttons, where they are?
Please look at DBAFBtns.Prg
Re: Billing system
Hi Marek
mol wrote:...where they are?
Perhaps I misunderstood your question :(
Floating buttons are file (table) name(s) at top (head) of browse of each table ;)
Re: Billing system
Hi Marek
mol wrote:...I've used arrow keys to navigate in "excel" style...
Did you tried SET NAVIGATIONMODE EXCEL ( mentioned here )
Re: Billing system
Hi Esgici,
Set navigationmode is to navigate inside a grid and that too in inplaceedit.
This navigation is inside a main window navigating through various buttons. Normally buttons can be navigated using tab. Marek has changed this to move around using arrow keys.
Re: Billing system
Writing
I had reactions on arrow keys on my mind.
But, I had to disable "ON KEY arrow-key ACTION...." phrases because they caused problem in Main Menu - it was almost impossible to use this menu by keyboard - only with mouse it worked good.
Re: Billing system
Hi Rathi and Marek
Thanks for valuable explanations :)
Playing keyboard's keys interested me since beginning of HMG ( aaah, that old-gold days, where is my INKEY(0) :?: ) :(
And IMHO, ON KEY is a weird command, by complexity and limits ( definable only for whole window, not for one control or a control groups) :(
It's also dangerous by probable complications with other tasks, especially activities of OS itself. :?
So I wonder everything about that subject.
Re: Billing system
It would be great to disable ACTION KEY's while activating top or context menu.
Re: Billing system
I too get this problem Esgici.
But I have avoided by using like this.
public lFocused := .f.
define window blah blah
   define grid blah
      row 10
      col 10
      on gotfocus lFocused := .t.
      on lostfocus lFocused := .f.
   end grid
   on key DOWN action doarrowaction()
end window
function doarrowaction
if lFocused
return nil
By this way, we can restrict the key usage to a single control.
Re: Billing system
mol wrote:It would be great to disable ACTION KEY's while activating top or context menu.
Hi Marek,
You can use above sample to enable lFocus whenever the user is in at least one button. If all the buttons are lost focus you just disable lFocus.
Re: Billing system
rathinagiri wrote: By this way, we can restrict the key usage to a single control.
Thanks Rathi :)
Nice idea :idea:
I will try it.
