Major bug in resource management
Ricci
Post by Ricci »
When working intensive with my HMG program after some time the controls began to disappear and the whole windows desktop was destroyed.
Using the Process Explorer I found out why this happens: while working the GDI handles grow and grow and when reaching 10000 the desktop becomes instable. 10000 hanles sounds really a lot and this is always enough, if a program close unused handles. HMG didn´t do this all the time.
Here´s a simple demonstration code:
#include "minigui.ch"
	DEFINE WINDOW Form_1 ;
		WIDTH 200 HEIGHT 100 ;
		MAIN
		@ 10,20 TEXTBOX TextBoxName ;
					 VALUE "" ;
					 WIDTH 100 HEIGHT 20 ;
					 FONT "ARIAL" SIZE 09
		@ 40,60 BUTTON ButtonNew ;
					 PICTURE "document-edit.bmp" ;
					 ACTION ButtonClick() ;
					 WIDTH 30 HEIGHT 30 FLAT
	ACTIVATE WINDOW Form_1
Function ButtonClick()
local xx
for xx := 1 to 1000
	 Form_1.ButtonNew.enabled := .F.
	 Form_1.ButtonNew.enabled := .T.
next
As you can see, if you press the button the program only disables and than enables the grafik button 1000 times. Doing this the reserves 8000 GDI handles. If you press the button the 2nd time, some strange things will happen to your destop. Don´t fear, nothing will be destroyed.
Below you can download the samlpe and the grafik.
test.zip
(1.05 KiB) Downloaded 325 times
Re: Major bug in resource management
Hmm. Sounds different and difficult.
I think Roberto can explain this.
Ricci
Post by Ricci »
I was trying it with another grafical element, the IMAGE control.
Here´s the code, this time i´m changing the picture of am IMAGE 1000 times:
		MAIN
					 VALUE "" ;
		@ 10,150 IMAGE lichtF PICTURE "lichtu.gif" WIDTH 35 HEIGHT 25
local xx
for xx := 1 to 1000
	 Form_1.lichtF.picture := "lichtb.gif"
	 Form_1.lichtF.picture := "lichtu.gif"
next
Here are the number of new GDI handles used for
a) grafical BUTTON control
<WindowName>.<ControlName>.Enabled := lEnabledState 4 handles
<WindowName>.<ControlName>.Visible := lEnabledState 0 handles
b) IMAGE control
<ParentWindowName>.<ControlName>.Picture := cImageName 1 handle
<WindowName>.<ControlName>.Enabled := lEnabledState 0 handles
For my program which uses a lot of grafical buttons and images with changes at every changed record this is a real disaster.
dhaine_adp
Post by dhaine_adp »
Hi Ricci,
It's great that you point out the GDI handle Leaks. While it is true that these leaks is a real problem against the application stability. However, you've never mentioned what O/S version, service pack and KB update installed on your test system. Of course we all do want to plug the GDI handle leaks.
I downloaded your posted test file for testing. It is really a major problem if just in case that all controls are leaking. Well it's too early to tell though.
Thanks for posting this info.
Danny
Danny
Manila, Philippines
dhaine_adp
Hi Ricci,
Using the Process Explorer I found out why this happens: while working the GDI handles grow and grow and when reaching 10000 the desktop becomes instable. 10000 hanles sounds really a lot and this is always enough. if a program close unused handles.
Yes, I agree with you, 10K is the default GDI Handle defined in the registry and we should think twice before increasing this value.
I don't know if all HMG Controls is leaking GDI Handles but through testing following your test code, one by one for each control, we'll be able to find if all of them is leaking. It could be from the core libs or from the windows GDI itself. At this point I am wondering if this problem do exist with HMG Extended because it use BCC as it's compiler...
Danny
Danny
Manila, Philippines
Ricci
Post by Ricci »
dhaine_adp wrote:Hi Ricci,
Hi Danny !
I use WinXP SP3 with all updates, but i´m sure this will happen on all other Win systems.
I think this only happens with controls that use grafik elements, i.e. IMAGE and BUTTON with PICTURE.
Regard ... Ricci
dhaine_adp
Hi Ricci,
I run your test app and have seen the effect of GDI handle leaks. Apparently the disappearance of the form controls is cause by lack of handles. IMHO Windbg can help to locate the problem. Unfortunately I can't download it from my connection at home. I'll try it from my office connection.
As of the moment I was planning to modify your test code and put it into a child window to get the full view of the handles once that window is terminated. It is more apparent that the image handle is not release that causes the leaks.
Ciao,
Danny
Danny
Manila, Philippines
Ricci
Post by Ricci »
Danny,
you can use the Sysinternals Process Explorer to see the increasing number of GDI handles.
dhaine_adp
Thanks for pointing out Sysinternals.
Well the main reason I'm interested with Windbg ( http://www.microsoft.com/whdc/ddk/debugging/ ) is that it can function as Kernel and User Mode/Interface App debugger. So that it can possibly tell which line of code or which portion of the source code the leaks came from against the library source code.
Anyway I hope that you posted the error in HMG Bugreport.
- Danny
Danny
Manila, Philippines
Ricci wrote:When working intensive with my HMG program after some time the controls began to disappear and the whole windows desktop was destroyed.
Hello Ricci,
Thanks for your bugreport!
There is a simple solution for this problem. We should replace some strings DeleteObject ( _HMG_SYSDATA [ 37 ] [y] ) with
IMAGELIST_DESTROY ( _HMG_SYSDATA [ 37 ] [y] ) in the h_controlmisc.prg and recompile HMG library by batch file hmg\source\makehmg.bat.
You have an updated (and tested) patch in the attachment of this message.
Hope that helps :idea:
h_controlmisc-upd.zip
Patch for GDI leaks problem
(33.25 KiB) Downloaded 320 times
