Checked menu item
Checked menu item
Hi All
I want "checked" status of a menu item depending on a logical variable.
Regarding HMG-Doc this possible with "alternate syntax" :
                  MENUITEM <cItemCaption>
                        ONCLICK <ActionProvedureName> | <bBlock>
                        [ NAME <MenuItemName>]
                        [ IMAGE <cImageName> ]
                        [ CHECKED <lValue> ]
Sadly, I'm unsuccessful :(
Where I'am wrong ?
PROC Main()
    DEFINE WINDOW frmChekMenu;
        WIDTH 400 ;
        HEIGHT 400 ;
        TITLE 'Checked Menu Items test' ;
        MAIN
        ON KEY ESCAPE ACTION frmChekMenu.Release
        DEFINE MAIN MENU
            POPUP "Test"
              lChecked := .T.
              MENUITEM "Checked"    CHECKED lChecked ONCLICK MsgBox( "Checked" )
              lChecked := .F.
              MENUITEM "Un-checked" CHECKED lChecked ONCLICK MsgBox( "Un-Checked" )
            END POPUP
        END MENU
    CENTER   WINDOW frmChekMenu
    ACTIVATE WINDOW frmChekMenu
RETU // Main()
Any idea ?
cdsaenz
Re: Checked menu item
Post by cdsaenz »
Strange. My memory on how to create commands in Clipper fails, but I just did a small change in MENUITEM (in my own program) and renamed it to MENUITEM2 as seen below and it works apparently.
I only changed CHECKED <.checked.> to CHECKED <checked>.
Or maybe it's a problem with the alternative syntaxes mixing up... Try the code below, it seems to work fine (we still need to figure out the problem in the base code)
#xcommand MENUITEM2 <caption> [ ONCLICK <action> ] [ NAME <name> ] [ IMAGE <image> ] [ CHECKED <checked> ];
_DefineMenuItem ( <caption> , <{action}> , <"name"> , <image> , <checked> )
PROC Main()
        WIDTH 400 ;
        HEIGHT 400 ;
        MAIN
        DEFINE MAIN MENU
            POPUP "Test"
              lChecked := .T.
              MENUITEM2 "checked" CHECKED lChecked ONCLICK MsgBox( "Checked" )
              lChecked := .F.
              MENUITEM2 "Un-checked" CHECKED lChecked ONCLICK MsgBox( "Un-Checked" )
            END POPUP
        END MENU
RETU // Main()
Charly
Argentina, Hobbyist developer, Clipper/Delphi/PHP/Progress
Thanks Charly, worked fine :)
I don't know meaning of enclosing parameters with periods and curly braces beside angle brackets, so what is difference between <.checked.> and <checked>.
I hope that Roberto will solve by the best way.
