Error proyect Sqlite
claudiotedesco
Hola
Quisiera saber porque me da el siguiente error el proyecto que estoy armando en SQLITE
Adjunto archivo
Gracias
Claudio
hbmk2: Processing configuration: E:\hmg\harbour\bin\hbmk.cfg
hbmk2: Processing: inicio.hbc
hbmk2: Compiling Harbour sources...
Harbour 2.0.0 (Rev. 13372)
Copyright (c) 1999-2010, http://www.harbour-project.org/
E:/hmg/SAMPLES/1ejer/sqlite/datosnombre.prg(14) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/SAMPLES/1ejer/sqlite/datosnombre.prg(16) Error E0030 Syntax error "syntax error at '.'"
2 errors
No code generated.
hbmk2: Error: Running Harbour compiler (embedded). 1
(E:\hmg\harbour\bin\harbour.exe) -n2 E:/hmg/SAMPLES/1ejer/sqlite/datosnombre.prg E:/hmg/SAMPLES/1ejer/sqlite/main_button_1_action.prg /q -o.hbmk\win\mingw\ -iE:/hmg/harbour/include -iE:/hmg//include -iE:/hmg/SAMPLES/1ejer/sqlite -iE:/hmg/SAMPLES/1ejer/sqlite/
Adjunto archivo
Gracias
Claudio
2 errors
No code generated.
- sqlite.rar
- (20.71 KiB) Downloaded 531 times
Re: Error proyect Sqlite
In datosnombre.prg file, you are referring a window which is not defined/activated in that file. Hence, we have to declare the same exclusively before calling any function (line no 2 after #include) as "declare window vnombre".
It has nothing to do with SQLite.
I have changed the codes to show the data in the grid correctly.
Please go through and ask me if you have any doubts.
claudiotedesco
Hola
Te agradezco tu gentil ayuda.
Cualquier cosa te aviso ti tengo problemas muchas gracias
Claudio
Hello
I appreciate your kind help.
Any thing you will notice I have trouble thank you very much
Claudio
Hello
Hi, all
So, there is any way to pass an entrie array to a Grid, differently of use:
for i=1 to xx
Grid1.additem({0,aCurRow})
next i
Some like: Grid1.aitems:=aCurRow, because it will be faster and easy
Ed
Hola, todos,
Hay alguna forma de pasar un array completo a un Grid, diferente a usar:
for i=1 to xx
next i
Algo como: Grid1.aitems:=aCurRow, porque esto seira mas rapido y facil de usar
Gracias,
Ed
for i=1 to xx
next i
Ed
Hola, todos,
for i=1 to xx
next i
Gracias,
Ed
We can use the following UDF for this.
Usage: setarrayitems("Form1","Grid1",aItems)
If you want to use
Form1.Grid1.Items := aItems
then, you have to insert as 95th line the following in c:\hmg\include\i_window.ch
The advantage is we can use this for Grid, ListBox and ComboBox controls.
In the case of Grid, we have to pass a two dimensional array and for others single dimensional.
So, it is very easy now to have like this:
form1.grid1.items := sql(dbo,"select name,address from personaldata order by name")
function setarrayitems(cFormName,cControlName,aItems)
local i := 0
Domethod ( cFormName, cControlName , "DELETEALLITEMS")
for i := 1 to len(aItems)
DoMethod(cFormName,cControlName,"ADDITEM",aItems[i])
next i
return nil
#xtranslate <w> . \<c\> . Items := \<a\> => SetArrayItems ( <"w">, \<"c"\> , \<a\> ) ;;
Hello Rathi and All Friends,
Have you tried Sql.prg codes with PostreSql? I tried it some months ago, but not successful
If we can do this, then we can use any of 3 RDBMSs (SQLite, MySql, PGSql) without much changing existing codes
Thanks in advance.
Thanks in advance.
Well. Let us try that too.
YESSSSrathinagiri wrote:Well. Let us try that too.
Thanks, rathinagiri
BTW, do you know if there are any UDF_lib.prg: because, i guess, there should be others interesting functions to save time.
Ed
Gracias, rathinagiri
A propósito, sabes si hay alguna UDF_lib.prg, porque creo que deben haber otras funciones interesantes para ahorrar tiempo.
Saludos,
Ed
Ed
Saludos,
Ed
