On change event fired on Date textbox
In date type textboxes, on change event is fired even before initializing the value (that may be because of inserting the date separator characters).
Please consider this example:
function main
define window sample at 0,0 width 200 height 200 main
   define textbox date1
      row 10
      col 10
      width 120
      date .t.
      on change msginfo("Date Changed")
   end textbox
   define textbox number1
      row 40
      col 10
      width 120
      numeric .t.
      on change msginfo("Number Changed")
   end textbox
end window
sample.center
sample.activate
return nil
Even before the window is activated, on change event is fired here for date textbox. It would be better to keep it equal for all controls.
Re: On change event fired on Date textbox
Hello Rathi,
I also found the same thing.
Previously I thought it's a behavior.
