checkbox FIELD property does not update the field
raumi75
Post by raumi75 »
Hello everyone,
sorry for not posting for so long. I have been busy with other projects but now I am back with my favorite programing language: HMG!
I noticed a strange behavior of the checkbox.
I used the FIELD-property and expected it to work just like in a TEXTBOX-control. It reads the value from the database field and when the user updates the control, the database field gets changed, too.
FIELD db->field
But in CHECKBOX, it displays the correct value (true = checked / false= unchecked) as it is saved in the database. But when I click to check or uncheck it, the database value does not get changed.
I have to do this by hand by supplying an ON CHANGE command.
ONCHANGE db->field := this.value
Am I doing something wrong or is this a bug in HMG?
Yours
Raumi
Re: checkbox FIELD property does not update the field
raumi75 wrote:Hello everyone,
FIELD db->field
Yours
Raumi
Welcome again.
I'll check it ASAP.
Hi Raumi
Are you sure in this sentence :
db is alias of your database file ?
If not, may be this is the problem.
Also, AFAIK FIELD is a reserved word and using it as a field name may be causing problem.
Moreover you may try REPLACE command or FIELDPUT() function instead of assignment operator ( := ) for changing content of a database file fields.
raumi75
Post by raumi75 »
esgici wrote:Hi Raumi
No. This not the real code. Just an example to show, what I did. The real code has variables in German, so I tried to simplify it a little bit.
The ONCHANGE event does the trick and my program runs fine.
It is just, that for other hmg-controls, the FIELD property also updates the database field and I don't have to write any ONCHANGE method. So if it is not a bug, it is at least a little inconsistent. And we know, how much Roberto loves consistency and simplicity. So I thought this worth mentioning.
Maybe Roberto can reproduce my error.
Raumi
Hi Raumi
Sorry, I'm misunderstood your question :(
And, checked <hmg>\SAMPLES\DATA.BOUND\datacontrols.prg :
We need separate "save" method each data.bound control for saving changed field value/content to database file.
Simply navigate (next/previous...) between records doesn't save data.
I don't know you have already done this.
raumi75
Post by raumi75 »
Thank you for pointing me to the DATA.BOUND samples. I am now playing with it.
If you add dbcommit() to the SAVE procedure, it stores your changes in the database.
Surprisingly, the TEXTBOX and CHECKBOX behave the same in the sample. I think, I will have to take a closer look at my own code. I hope, I am not wasting your time.
Raumi
raumi75 wrote: ...
Absolutely no, my friend, everything is for HMG and HMG community :D
raumi75
Post by raumi75 »
OK. I have found my bug. HMG works fine. Sorry for this post.
Thanks giving me the right hints!!
Raumi
raumi75 wrote:OK. I have found my bug. HMG works fine. Sorry for this post.
Raumi
No problem and congratulations for your great victory!!!
And thanks for the help Esgici.
