BITMAP.CH
BITMAP.CH
Hello everyone.
I leave here a set of functions to manipulate BMP images.
I have attached four examples:
1) RUN HORSE: graphic animation (movie)
2) VIEW IMAGE: view BMP image, load, save, rotate, transform, copy / paste clipboard, capture desktop, change the brightness, etc.
3) AIR FIRE: down planes with anti-aircraft battery
4) MOVE DOG: Move a dog
Claudio Soto.
* PROGRAMA:	BITMAP.CH
* LENGUAJE: HARBOUR-MINIGUI 3.0.34
* FECHA:	12 JUNIO 2010
* AUTOR:	Dr. CLAUDIO SOTO SILVA
* PAIS:		URUGUAY
* E-MAIL:	srvet@adinet.com.uy
* Functions that manipulate the native control IMAGE of HMG (Image Control HMG = static window)
* IMAGE_GET_hWND     (cWinName, cImageName) ====> Return hWnd
* IMAGE_GET_hBITMAP  (cWinName, cImageName) ====> Return hBitmap
* IMAGE_SET_hBITMAP  (cWinName, cImageName, hBitmap, Width, Height) ====> Set and show hBITMAP in IMAGE Control of HMG
* IMAGE_SHOW_hBITMAP (hWND, hBitmap)           ====> Show hBitmap in IMAGE Control of HMG
* Functions that manipulate BITMAP
* BMP_GET_INFO   (hBitmap, Info) ---> Return BMP_INFO_xxx
* BMP_LOAD_FILE  (cFileBMP) ---> Return hBITMAP
* BMP_SAVE_FILE  (hBitmap, cFileBMP) ---> Return Success (TRUE or FALSE)
* BMP_CREATE     (Width, Height) ---> Return hBITMAP
* BMP_RELEASE    (hBitmap) ---> Return Success (TRUE or FALSE)
* BMP_RESIZE     (hBitmap, New_Width, New_Height, modo_stretch) ---> Return new_hBitmap
* BMP_TRANSFORM  (hBitmap, modo, Angle, Color_Fill) ---> Return New_hBitmap
* BMP_SET_PIXEL  (hBitmap, x, y, Color_RGB)
* BMP_GET_PIXEL  (hBitmap, x, y) ---> Return {R,G,B}
* BMP_GET_SPRITE          (hBitmap, x, y, Width, Height) ---> Return new_hBITMAP
* BMP_PUT_SPRITE          (hBitmap_D, x1, y1, hBitmap_O, x2, y2, Width2, Height2)
* BMP_ISPOINT_IN_SPRITE   (Px, Py, hBitmap, x, y, Width, Height, Color_Transp, modo)
* BMP_IS_INTERSECT_SPRITE (hBitmap1, x1, y1, Width1, Height1, Color_Transp1, hBitmap2, x2, y2, Width2, Height2, Color_Transp2, modo)
* BMP_CLIPBOARD_EMPTY ()      ---> Return TRUE (Empty clipboard: DIB format) or FALSE (Not empty clipboard)
* BMP_GET_CLIPBOARD   ()      ---> Return hBitmap (Success) or 0 (Failure or Clipboard Empty DIB format)
* BMP_PUT_CLIPBOARD (hBitmap) ---> Return Success (TRUE or FALSE)
* BMP_COPY_BITBLT         (hBitmap_D, x1, y1, Width1, Height1, hBitmap_O, x2, y2)
* BMP_COPY_STRETCHBLT     (hBitmap_D, x1, y1, Width1, Height1, hBitmap_O, x2, y2, Width2, Height2, modo_stretch)
* BMP_COPY_TRANSPARENTBLT (hBitmap_D, x1, y1, Width1, Height1, hBitmap_O, x2, y2, Width2, Height2, Color_RGB_Transp, modo_stretch)
* BMP_COPY_ALPHABLEND     (hBitmap_D, x1, y1, Width1, Height1, hBitmap_O, x2, y2, Width2, Height2, Alpha, modo_stretch)
* BMP_SHOW                     (hWnd, x, y, Width, Height, hBitmap, modo_stretch)
* BMP_PUTSCREEN_BITBLT         (hWnd, x1, y1, Width1, Height1, hBitmap, x2, y2)
* BMP_PUTSCREEN_STRETCHBLT     (hWnd, x1, y1, Width1, Height1, hBitmap, x2, y2, Width2, Height2, modo_stretch)
* BMP_PUTSCREEN_TRANSPARENTBLT (hWnd, x1, y1, Width1, Height1, hBitmap, x2, y2, Width2, Height2, color_transp, modo_stretch)
* BMP_PUTSCREEN_ALPHABLEND     (hWnd, x1, y1, Width1, Height1, hBitmap, x2, y2, Width2, Height2, Alpha, modo_stretch)
* BMP_GETSCREEN_BITBLT         (hBitmap, x1, y1, Width1, Height1, hWnd, x2, y2)
* BMP_GETSCREEN_STRETCHBLT     (hBitmap, x1, y1, Width1, Height1, hWnd, x2, y2, Width2, Height2, modo_stretch)
* BMP_GETSCREEN_TRANSPARENTBLT (hBitmap, x1, y1, Width1, Height1, hWnd, x2, y2, Width2, Height2, color_transp, modo_stretch)
* BMP_GETSCREEN_ALPHABLEND     (hBitmap, x1, y1, Width1, Height1, hWnd, x2, y2, Width2, Height2, Alpha, modo_stretch)
* BMP_CLEAN              (hBitmap, x, y, Width, Height, color_RGB)
* BMP_GRAY               (hBitmap, x, y, Width, Height, gray_level)       gray_level = 0 To 100%
* BMP_LIGHT              (hBitmap, x, y, Width, Height, light_level)       light_level = -255 To +255
* BMP_CHANGUE_COLOR      (hBitmap, x, y, Width, Height, old_RGB, new_RGB)
* BMP_CHANGUE_COLOR_DIST (hBitmap, x, y, Width, Height, RGB_Color, new_RGB, Dist, Comp)
* BMP_TEXTOUT (hBitmap, x, y, Text, FontName, FontSize, Text_Color, Back_color, Type, Align)
* Functions that implement direct GDI functions
* GDI_GET_PIXEL (hWND, x, y) ---> Return {R,G,B}
* GDI_SET_PIXEL (hWND, x, y, Color_RGB)
* Miscellaneous functions
* WIN_GETCURSOR_POS (hWnd) ---> Return {x,y}
* WIN_SETCURSOR_POS (hWnd, x, y)
* WIN_GET_CLIENT_RECT (hWnd) ---> Return {Width, Height}
* WIN_GET_hWND (cWinName)  ---> Return hWnd
* BMP_DESKTOP_hWND          ---> Constant 0
* Functions that DELAY execution of the program
* SYS_DELAY (nTicks)                --->  1000 Ticks/seg ---> 1 Ticks = 1 MiliSeg (define in time.h)
* SYS_DELAY_WITH_DOEVENTS (nTicks)  --->  1000 Ticks/seg ---> 1 Ticks = 1 MiliSeg (define in time.h)
* SYS_CLOCK ()                      ---> Return nTicks
* BMP constant definition
// BMP_Get_Info()
#define BMP_INFO_WIDTH     0
#define BMP_INFO_HEIGHT    1
#define BMP_INFO_BITSPIXEL 2
//  BMP_Transform ()
//           MODO                         ANGLE                       COLOR_FILL
#define BMP_REFLECT_HORIZONTAL 1   //     Not use                     Not use
#define BMP_REFLECT_VERTICAL   2   //     Not use                     Not use
#define BMP_ROTATE             4   //     Angle (0 to 360 degree)     Color fill blank space
//  BMP_IsPoint_In_Sprite ()
//  BMP_Is_Intersect_Sprite ()
#define BMP_OPAQUE       0
#define BMP_TRANSPARENT  1
//                                                       _x_ ---> _Copy_, _PutScreen_, _GetScreen_
#define BMP_SCALE   0   // BMP_SHOW(),  BMP_Resize(), BMP_x_StretchBlt(), BMP_x_TransparentBlt(), BMP_x_AlphaBlend()
#define BMP_STRETCH 1   // BMP_SHOW(),  BMP_Resize(), BMP_x_StretchBlt(), BMP_x_TransparentBlt(), BMP_x_AlphaBlend()
#define BMP_COPY    3   // BMP_SHOW()
//BMP_Gray ()       gray_level = 0 To 100%
#define BMP_GRAY_NONE 0
#define BMP_GRAY_FULL 100
// BMP_Light ()    light_level = -255 To +255
#define BMP_LIGHT_BLACK -255
#define BMP_LIGHT_NONE  0
#define BMP_LIGHT_WHITE 255
// BMP_Changue_Color_Dist()
#define BMP_CHANGUE_COLOR_DIST_EQ 0    // DIST() == Dist  ---> (equal)
#define BMP_CHANGUE_COLOR_DIST_LE 1    // DIST() <= Dist  ---> (less or equal)
#define BMP_CHANGUE_COLOR_DIST_GE 2    // DIST() >= Dist  ---> (great or equal)
// BMP_TextOut()
#define BMP_TEXTOUT_OPAQUE      0
#define BMP_TEXTOUT_TRANSPARENT 1
#define BMP_TEXTOUT_BOLD        2
#define BMP_TEXTOUT_ITALIC      4
#define BMP_TEXTOUT_UNDERLINE   8
#define BMP_TEXTOUT_STRIKEOUT   16
#define BMP_TEXTOUT_LEFT        0
#define BMP_TEXTOUT_CENTER      1
#define BMP_TEXTOUT_RIGHT       2
BITMAP.CH.rar
(3.98 MiB) Downloaded 929 times
Last edited by srvet_claudio on Mon Jun 28, 2010 1:44 am, edited 2 times in total.
Re: BITMAP.CH
srvet_claudio wrote:Hello everyone.
Nice!!!
Thanks!!!!!!
Re: BITMAP.CH
Roberto Lopez wrote:Nice!!!
Thanks!!!!!!
Thanks Roberto.
Hello everyone:
Attention:
In the previous post,
I changed (Mon June 28, 2010 1:45 a.m.) the original file by the current BITMAP.CH.rar (due to a small bug in the original).
Sorry for the inconvenience.
Claudio Soto
PD:If your downloaded the original file, please download again and change original file for the new file.
Re: BITMAP.CH
Thanks a lot Claudio. Really helpful.
dhaine_adp
Re: BITMAP.CH
Post by dhaine_adp »
Hi Doctor,
Thank you very much for your contribution. It's cool!
Danny
Danny
Manila, Philippines
Re: BITMAP.CH
Fantastic work! So, we can expect a fun game soon in HMG! :) Whoo!
But, the first sample (run horse) crashes for me. Mine is Win XP.
Re: BITMAP.CH
Thanks Dr. :)
Good work, best performence :D
Re: BITMAP.CH
Amigo Claudio
Fenomenal !!!!
Gracias por compartir
Un abrazo
Mustafa ;)
Re: BITMAP.CH
Thanks Rathinagiri, Danny, Marek, Esgici and Mustafa.
