Hello All,
I was busy in my work (and you can feel how a programmer feels when an easy code doesn't work
I can export the header of dbf successfully but found problem with exporting data
Here is the sourcecode.
I used .xml file format from
http://en.wikipedia.org/wiki/Microsoft_ ... ML_formats (I got the url from Rathi, a few days ago)
Grigory, Thank you. I downloaded your app, but it can't detect my old VFP .dbf file (showing message - file is corrupted). It works for my harbour/xharbour generated .dbf files. Output is fine and generic. Can we get the output in the way that a spreadsheet program can understand and display data?
As, I started my small app before seeing your post, I gave the same name of your app (dbf2xml). Sorry, I shall change it later.
My request to all to please check my source the code and send your suggestion. May be the bug is for my careless mistakes.
Thanks in advance
