Problem with Print Preview in Win98
dani455
Post by dani455 »
Español:
Hola,
Utilizo HMG267, y en los equipos Win98/Me, la vista previa queda en blanco y sus íconos no me aparecen. ¿Qué puede ser?
Gracias.
English:
I use HMG267, and the pc with Win98, the Print Preview is blank and the icons do not appear.
What could it be?
Thanks.
Re: Problem with Print Preview in Win98
dani455 wrote: Hi,
What could it be?
Thanks.
Hi dani,
I don't confirm this problem with Win98SE (was tested by sample at folder samples\Print\ImageFromResourse\Bmp).
Please be so kind to verify your PC configuration and compiling paths.
dani455
Post by dani455 »
OK Grigory, follow your advice and I will tell you what happened.
Thank you very much for your response.
As far as your problem is concerned, it seems that, it is because of resource compiling and linking.
Where did you install HMG? To the default directory c:\hmg?
dani455
Post by dani455 »
Hi, rathinagiri.
Yes. I have it in c: \ HMG.
Hi Dani,
Are you using HMG-IDE or compile.bat to build the application?
And, whether this is a problem of HMG 2.67 version alone? Whether it worked before?
Can you give a screenshot?
dani455
Post by dani455 »
I tried with the IDE and with the compile.bat.
I send the screenshot.
Thanks.
pantalla.rar
(11.52 KiB) Downloaded 356 times
Had you tried other samples as given in c:\hmg\samples\print?
dani455 wrote:I tried with the IDE and with the compile.bat.
Thanks.
Prior to continue, could be you so kind to delete all previous HMG and IDE installations and reinstall all ?
This way, we could assure that there is no problem with installation.
TIA.
Thanks.
And... are you from Buenos Aires ?
