Adaptation of FiveWin class TsBrowse to HMG
Source code related resources
IMATECH
Re: Adaptation of FiveWin class TsBrowse to HMG
Post by IMATECH »
Hello Sr. Rathinagiri, Sr.: Esgici
Many thanks for help me on this treat...
and
Sorry for changing my post's to disponibilize just last changes ( including just all files changed since 3.0.41)...
But this is a work in progress and any new updates result in a full rebuild of the Lib to basicaly correct bugs detected.. And for user tests, I think is important to get a stable Lib for this support ( not only for tell-me: I found a bug that I have fixed in last update)...
My first choice was to exchange and sincronize modifications with a team ( anybody working on the project sources ) and do not publish nothing here until a global decision for this... Then only me and Sr. Rathinagiri are working in this release (and waiting the rest of team or aditional support on how to make this work)...
Please, if you have any idea to help... Let us know...
Best regards...
M., Ronaldo
By: IMATECH
Imation Tecnologia
Hi Chacal.GO,
I feel uncomfortable when you call me as Sr. So, please call me Rathinagiri or simply Rathi. :)
Then, Esgici could not find your post since you have modified your older post. Instead, you can post a new reply to the same topic. Thereby everybody can know about the post.
I am verifying the source code with the official MingW compiler and I will let you know soon.
rathinagiri wrote:
I feel uncomfortable when you call me as Sr. ...
Me too :(
Chacal.GO wrote: ...
My humble idea is:
dBase based Clipper is a high level programming language and don't have hard typing and similar low-level programming concepts. Harbour is the same. Personally, I am programming for many many years without obey some unnecessary rules like "define / declare variables before use". And never encountered any problem on this way (scope of variables is another issue). So, eliminating harmless warning messages like "Ambiguous reference" is totally needless effort for me. And I guess most of members of our forum think like me, because I don't see any complaint from them.
On the other hand, again as my opinion, a big project like HMG become more fragile day to day while it growing up. When changing any point, never couldn't know where, when and how a problem will occurs. This is correct non for anyone, but for original author(s) too. So, I (personally) never trust such global modification made externally.
Eventually, as users, we can contribute by offering some extra features, fixing some problems (if any), join to development stage of some new attempts (such as HMGScript ) and so on.
I don't never want keep down excitements of new and young friends; my only purpose is recommending that everyone will use their effort and time on right and useful way.
Again, all of my speech is my personal ideas and I don't want hurt anyone for anything and anyway.
Saludos / regards
IMATECH
Post by IMATECH »
Hi Esgici :)
*** Yep: and nothing will change about it ;)
*** Then I think about other projects, like: Psql, Linux, Harbour, etc... this projects is big enough what !
*** Hmg can be better: just it...
Thanks for questions...
Best regards...
[Sr.: ] In Americas this is a way to show respect for next peoples ...
I have a car made in Turkiye... one of the best from FORD industry... ;)
Please: Could you give me a help ?
Using your search engine, find the value in U$D for: Ford Transit Service kit 2.4 Tdci (sample links below)
http://www.ebay.co.uk/itm/Genuine-Ford- ... 4ab76e9e86
http://www.ebay.co.uk/itm/FORD-TRANSIT- ... 3a74f4bf2c
http://www.ebay.co.uk/itm/FORD-TRANSIT- ... 4166627e85
M., Ronaldo
By: IMATECH
Imation Tecnologia
IMATECH
Post by IMATECH »
Hello Rathi :)
Testing with XBrliant... All Works fine...
StartUp seems faster than before recompiling the project...
Nice and beauty program ;)
Best regards...
XBRLiant.rar
Compilled with msvc ( vs2010 express )
This is an App from Rathi...
You can download it from:
http://www.xbrliant.in/
(936.04 KiB) Downloaded 524 times
M., Ronaldo
By: IMATECH
Imation Tecnologia
Thanks a lot. :) Actually it is for Indian Companies, but can be a sample for any XBRL implementation.
Had you seen Xtract DataCube?
http://hmgforum.com/viewtopic.php?f=10&t=823
http://hmgforum.com/viewtopic.php?f=10&t=960&start=10
Chacal.GO wrote:Hello Rathi :)
Nice program ;)
Best regards...
You forgot to append database...
IMATECH
Post by IMATECH »
Hello Mol...
This is an App from Rathi... that you can download it from:
M., Ronaldo
By: IMATECH
Imation Tecnologia
IMATECH
Post by IMATECH »
Hi Rathi...
Wow... You make it so simple... :)
*** And I have discovered many errors in my intentions making changes on hmg core ***
*** Will restart from Zero and make just a minimum changes needed for my purposes ***
*** Then I'm will working just to Add TsBrowse 9 in my projects... ***
*** and whem it works I will show to you again ***
Data analisis in Delphi is some more dificult to understand and apply (But not from now)...
Many, many Thanks for this instant upgrade to my mind...
Best regard's...
Ronaldo M.
*** Many years ago I planed to build a mini WorkSheet to use inside an app (like a caledar, calculator) ...
*** Based in a mini matrix ( multidimensional array of array : 64 * 64 ) just to fit in oScreen, ofering basic funtions for simple calcs ( aVert x Ahoriz ): [ +, -, /, *, mod, avg, etc...]
*** I got no success at that time...
*** Now You give me a new impetus to produce this with HMG (and invicted you to join this idea)
M., Ronaldo
By: IMATECH
Imation Tecnologia
