Gridlines for ListBox
Can we have Gridlines for ListBox as in Grid?
Re: Gridlines for ListBox
rathinagiri wrote:Can we have Gridlines for ListBox as in Grid?
Nop!
AFAIR, Windows API don't have such feature.
You could use a grid with no headers and only one column.
That will give you the same result.
Thanks for the answer and instant solution Roberto. :)
Roberto Lopez wrote: ...
You could use a grid with no headers ...
Header-less GRID ? Not "empty header", isn't ?
Please give a little example; I need eagerly it !
Best regards
jparada
Post by jparada »
Hi Esgici,
Please take a look at this:
Please modify grid.02 example and apply the change:
NOHEADERS ;
instead of
HEADERS {'Column 1','Column 2','Column 3'} ;
Best Regards
Javier
Gracias Javier
I had missed it in the documentation :(
