GRID con MDB
claudiotedesco
GRID con MDB
Post by claudiotedesco »
Hola Gente
Le adjunto un ejemplo utilizando el GRid con una base MDB
Me da el siguiente error:
Error DBCMD/2001 Workarea not in use: DBEVAL
Called from DBEVAL(0)
Called from GETDATAGRIDRECCOUNT(2651)
Called from _DEFINEGRID(139)
Called from MAIN(75)
Si alguien me puede ayudar se los agradezco
eje13.rar
(606.28 KiB) Downloaded 448 times
Re: GRID con MDB
claudiotedesco wrote:Hola Gente
This is not a bug.
This is a problem in your code.
Your workarea alias is "base"
DBUSEAREA( .T.,, "select * from articulos", "base" )
But your RowSOurce property is set to "articulos"
ROWSOURCE "articulos"
Correcting that your sample works fine.
claudiotedesco
Re: GRID con MDB
Muchas gracias por tu respuesta
