Help with grid again
Czarny_Pijar
Post by Czarny_Pijar »
This code
FUNCTION MAIN
  Use b1emp Shared
   DEFINE WINDOW Form_1;
                WIDTH  330;
                HEIGHT 240;
                MAIN
		@ 10, 10 GRID Grid_1;
			WIDTH 300;
			HEIGHT 160;
			HEADERS {"No","Name"};
			WIDTHS  {140,150};
			ROWSOURCE "b1emp" ;
			VALUE { 1 , 1 } ;
			COLUMNCONTROLS {{'TEXTBOX','NUMERIC','9999'},{'TEXTBOX','CHARACTER'}};
			COLUMNFIELDS {'emp_no','emp_name'}
   CENTER WINDOW Form_1
   ACTIVATE WINDOW Form_1
works as expected.
I have been trying do the same things with IDE (see the attachment). I've checked everything twice, and now I wonder, it is a bug or my subsequent eclipse?
grid_ide_dbf.zip
(2.6 KiB) Downloaded 199 times
Re: Help with grid again
Czarny_Pijar wrote:This code
FUNCTION MAIN
  Use b1emp Shared
                WIDTH  330;
                HEIGHT 240;
                MAIN
			WIDTH 300;
			HEIGHT 160;
			WIDTHS  {140,150};
			ROWSOURCE "b1emp" ;
			VALUE { 1 , 1 } ;
works as expected.
In main.fng, the rowsource line has an extra single quote. Please, correct it and try again.
ROWSOURCE "'b1emp"
Czarny_Pijar
Roberto Lopez wrote:In main.fng, the rowsource line has an extra single quote. Please, correct it and try again.
ROWSOURCE "'b1emp"
Yes, this type of errors I hate most. As we can see, these days, when I can live without glasses, pass away forever.
Unfortunately, correct this error did not help, still the same error pops up.
Error DBCMD/2001 Workarea not in use: DBEVAL
Called from DBEVAL(0)
Called from GETDATAGRIDRECCOUNT(2651)
Called from _DEFINEGRID(139)
Called from MAIN(54)
================== Edit =================
This information was taken from a previous version, HMG 3.0.31. In the current version 3.0.32 this is changed slightly:
Called from GETDATAGRIDRECCOUNT(2644)
grid_ide_dbf.zip
Corrected, but still not working sources
(2.6 KiB) Downloaded 182 times
ROWSOURCE "'b1emp"
Ok. I'll check it again.
ROWSOURCE "'b1emp"
The problem is not really related with IDE.
In fact the two samples are different, since, in the first you open the table before creating the grid and in the other the table is opened in the OnInit procedure.
The true problem is that the grid definition procedure requires that the table be already open.
Roberto Lopez wrote: The true problem is that the grid definition procedure requires that the table be already open.
I'll add a notice about this in documentation and appropriate error checking at Grid definition.
