how to explore many tables
Hi friends,
I need your help to understand which is the best way or approach to explore concurrently some tables.
I have this pattern tables (limited to fields that are correlated with each other):
Tab1.FieldN = Id_Code => Primary Key
Tab2.FieldX = Id_Code => Indexed but not Primary Key
Tab3.FieldY = Id_Code => Indexed but not Primary Key
Where Id_Code is the same value: typical example of a relationship of one to many!
one Tab1.Record to many Tab2.Records
one Tab1.Record to many Tab3.Records
With the Xbase language, I think I can use two alternative:
A) DBSETRELATION or B) FILTER
My problem is: how can I scan from the beginning to the end of Tab1 and concurrently scan all related records on both Tab2 and Tab3?
Many thanks in advanced
Luigi from Italy
www.L3W.it
www.L3W.it
- dhaine_adp
Re: how to explore many tables
Hi Luigi,
In traversing the tables, you should use do while loop and check your primary key against the key of the second table and on the third table and so on. That is a loop within a loop.
But make sure that you would not end up in endless loop. Example:
I hope that helps...
Danny
function main()
local PrimaryKey, DetailKey, RemKey
use invoicehead alias INVHEAD new
index on InvoiceNbr to Invoice
use invoicedetails alias INVDETL new
index on InvoiceNbr
use remarks alias REMARKS new
index on InvoiceNbr+LineNbr
dbselect("INVHEAD")
dbgotop()
do while !eof()
PrimaryKey := INVHEAD->InvoiceNbr
do while !eof() .and. INVDETL->InvoiceNbr == PrimaryKey
DetailKey := PrimaryKey + LineNbr
do while !eof() .and. ( ( REMARKS->InvoiceNbr + REMARKS->LineNbr ) == DetailKey )
dbskip()
enddo
dbskip()
enddo
dbskip()
enddo
dbcloseall()
return
Danny
Danny
Manila, Philippines
Danny
Manila, Philippines
Hi Danny,
Shouldn't select relevant table before giving dbskip()?
- dhaine_adp
Thanks for pointing out the mistake I made...Shouldn't select relevant table before giving dbskip()?
Luigi,
Sorry, here is the corrected sample:
function main()
index on InvoiceNbr
dbselect("INVHEAD")
dbgotop()
do while !eof()
dbselectarea( "INVDETL")
dbseek( PrimaryKey )
dbselectarea( "REMARKS" )
dbseek( DetailKey )
dbskip()
enddo
dbselectarea( "INVDETL" )
dbskip()
enddo
dbselectarea( "INVHEAD" )
dbskip()
enddo
dbcloseall()
return
Danny
Manila, Philippines
Danny
Manila, Philippines
Hi friends,
many thanks for your quickly answer.
Thanks Dany, but what you have proposed is also what I normally use. I thought there was a different solution, another pov. Anyway thank you very much for your interest.
To avoid problems reported by Rathi, I always use the table name before the instructions as "DBGOTOP, DBSKIP" without using "DBSELECTAREA" that I use only in specific situation
This question is borned because I'm try to develope a simple contact manager, that I want publish and submit to HMG forum, and I want to make it "fairly" well
and I have some tables with the same referrer.
Best Regards
Best Regards
Luigi from Italy
www.L3W.it
www.L3W.it
Contact Manager?!
Very good Luigi. Waiting for your utility...
- Czarny_Pijar
Unfortunately, the code provided by dhaine_adp does'nt fulfill the requirements of l3whmg:
1st - straight from the school board, and
2nd - optimezed for speed ( both checked, works well).
Sorry for the delay, the problems with the IDE and the grids has been just resolved
Look at the attachment for the correct solution, even in 2 flavours:l3whmg wrote: typical example of a relationship of one to many!
- master_deatail_scan.zip
- (3.23 KiB) Downloaded 511 times
Hy Czarny_Pijar,
many thanks for your answer: I'll look at your example!
Best Regards
Best Regards
Luigi from Italy
www.L3W.it
www.L3W.it
- nguyenchiduc
I have to work with multiple tables at once, each table is a different index. Each table has hundreds of thousands or millions of records
Results return to the temporary tables. For example data_view1, data_view2 ... data_view_n
If the search index is used to return results very quickly even though many records, search on multiple tables to retrieve relevant information
Definition of GRID for data_view1, data_view2 ... data_view_n to see the results on screen.
@ x1, y1 GRID Grid_data_view1 ... ROWSOURCE 'data_view1'
@ X2, y2 GRID Grid_data_view2 ... ROWSOURCE 'data_view2'
@ xn, yn GRID Grid_data_view_n ... ROWSOURCE 'data_view_n'
For example, I have the table:
Table1: index1
Table2: index1, index2 ...
Table3: index2, index3 ...
Table_N: index_(n-1), index_n ...
Table1: index1
select data_view1
zap
select data_view2
zap
select data_view_n
zap
select Table1
seek object_search_1
IF FOUND() == .T.
select Table2
seek Table1->object_search_1
IF FOUND() == .T.
select Table3
seek Table2->object_search_2
IF FOUND() == .T.
select Table4
seek Table3->object_search_3
IF FOUND() == .T.
DO WHILE Table3->object_search_3 == something
select data_view
append blank
data_view-Field1 := Table3->Field1
data_view-Field2 := Table3->Field2
data_view->FieldN := Table3->FieldN
data_view->( DBCOMIT() )
skip
ENDDO
/* Else Commands */
/* Else Commands */
/* Else Commands */
/* Else Commands */
- nguyenchiduc
Below is a main table of data (bottom), looking from 4 different tables. Each table has hundreds of thousands to millions of records
The displayed information is always changing depending on the change of the main table.
