Problema con el GRID 2
Hola Roberto,
aparentemente DYNAMICBACKCOLOR y DYNAMICFORECOLOR no funcionan cuando el GRID se carga a partir de una matriz.
Saludos,
Claudio Soto
FUNCTION MAIN
mat := {{"Juan","A"},;
        {"Pedro","C"},;
        {"Jose","B"},;
        {"Maria","C"}}
   DEFINE WINDOW Form_1;
                 WIDTH 640;
                 HEIGHT 580;
                 MAIN
                PRIVATE bColor := {|| if ( This.CellRowIndex/2 == int(This.CellRowIndex/2), RGB(128,128,128) , RGB(192,192,192))}
                PRIVATE fColor := {|| RGB (255,0,0)}
                @ 100, 10 GRID Grid_1;
                          WIDTH 580;
                          HEIGHT 300;
                          HEADERS {"Nomb","Cargo"};
                          WIDTHS  {400,150};
                          ITEMS mat;
                          DYNAMICBACKCOLOR {bColor , bColor};
                          DYNAMICFORECOLOR {fColor , fColor}
   CENTER WINDOW Form_1
   ACTIVATE WINDOW Form_1
Re: Problema con el GRID 2
srvet_claudio wrote:Hola Roberto,
Saludos,
Claudio Soto
FUNCTION MAIN
        {"Pedro","C"},;
        {"Jose","B"},;
        {"Maria","C"}}
                 WIDTH 640;
                 HEIGHT 580;
                 MAIN
                          WIDTH 580;
                          HEIGHT 300;
                          WIDTHS  {400,150};
                          ITEMS mat;
I'll check it ASAP.
I think you don't use RGB() of function here. We have to return an array of three numbers between 0-255.
rathinagiri wrote:I think you don't use RGB() of function here. We have to return an array of three numbers between 0-255.
Yes, it's true.
Thanks, you saved me a review!
Thanks Rathi, you're right.
Roberto, in the tutorial of HMG appears:
bColor := { || if ( This.CellRowIndex/2 == int(This.CellRowIndex/2) , RGB (128,128,128) , RGB (192,192,192) ) }
Sorry for the inconvenience.
Greetings to both,
Claudio Soto.
srvet_claudio wrote: Roberto, in the tutorial of HMG appears:
I've not found that in any sample or doc.
Could be you so kind to point me exactly where is it to correct it?
TIA.
Roberto Lopez wrote:I've not found that in any sample or doc.
C:\hmg.3.0.32\DOC\data\dynamicbackcolor.htm
C:\hmg.3.0.32\DOC\data\dynamicforecolor.htm
Saludos,
Claudio Soto
Saludos,
Claudio Soto
Fixed.
Thanks!
