Hello,
Finally I want to change all Browse command to Grid, but I found a problem with opening database in procedure test ( open with doubleclikc) (HMG 3.0.30 on Win 7 Enterprise 32 bit):
DEFINE WINDOW predrac ;
AT 20,20 ;
WIDTH getdesktopWidth()-50 ;
HEIGHT getDeskTopHeight()-120 ;
TITLE 'Test' ;
MAIN
select 1
use gl_pred alias gl_pred
go top
select 2
use naslovi alias naslovi
select 1
go top
@ 65,5 GRID Grid_pred ;
WIDTH getdesktopWidth()-70 ;
HEIGHT getDeskTopHeight()-250 ;
HEADERS { 'Štev.','Šifra','Ime kupca','Datum','Znesek','Rabat','DDV','Zaslužek','Znesek za plačilo',;
'Dod.stroški','Datum plačila','Valuta','Knjižen','Status','Plačano po','predračunu',;
'Vrsta','Zav.za davek'} ;
WIDTHS { 50,50,240,100,90,90,90,90,100,90,100,50,50,50,90,80,40,40 } ;
ROWSOURCE "GL_PRED" ;
COLUMNFIELDS { 'STEV','SIFRA','NASLOVI->NAZIV','DATUM','transform(round(rabat,2),"@E 99,999,999.99")',;
'transform(round(rabat,2),"@E 9,999,999.99")','transform(round(davek,2),"@E 9,999,999.99")',;
'transform(round(prep,2),"@E 9,999,999.99")','transform(round(skupaj,2),"@E 9,999,999.99")',;
'transform(round(ptt,2),"@E 9,999,999.99")','DATUM_PLA','VALUTA','KNJ','STATUS','transform(PLACANO,"@E 9,999,999.99")','PRED',;
'substr(KON,2,1)', 'substr(naslovi->KOM2,46,1)' } ;
JUSTIFY { BROWSE_JTFY_LEFT,BROWSE_JTFY_LEFT,BROWSE_JTFY_LEFT,BROWSE_JTFY_LEFT,;
BROWSE_JTFY_RIGHT,BROWSE_JTFY_RIGHT,BROWSE_JTFY_RIGHT,BROWSE_JTFY_RIGHT,BROWSE_JTFY_RIGHT,BROWSE_JTFY_RIGHT,;
BROWSE_JTFY_RIGHT,BROWSE_JTFY_RIGHT,BROWSE_JTFY_RIGHT,BROWSE_JTFY_RIGHT,BROWSE_JTFY_RIGHT,BROWSE_JTFY_RIGHT };
TOOLTIP 'Seznam predračunov' ;
ON DBLCLICK test() ;
FONT 'ARIAL' SIZE 10 ;
CENTER WINDOW predrac
ACTIVATE WINDOW predrac
close databases
return
procedure test()
select naslovi
msginfo("test")
select gl_pred
return
Best regards Rado
Problem with Grid
radohabjan
Problem with Grid
- TESTGRID.ZIP
- (698.48 KiB) Downloaded 376 times
- HMG Founder
Re: Problem with Grid
Thanks for the report.
I'll review it ASAP.
- HMG Founder
This is not a bug.radohabjan wrote: Finally I want to change all Browse command to Grid, but I found a problem with opening database in procedure test ( open with doubleclikc) (HMG 3.0.30 on Win 7 Enterprise 32 bit):
No default workarea is assumed to process expressions, so, if you use fields inside expressions, you must aliase it.
In your case DAVEK, PREP, SKUPAJ, PTT, PLACANO and KON must be aliased with GL_PRED->.
So, the correct 'ColumnFields' line is:
COLUMNFIELDS { 'STEV','SIFRA','NASLOVI->NAZIV','DATUM','transform(round(rabat,2),"@E 99,999,999.99")','transform(round(rabat,2),"@E 9,999,999.99")','transform(round(GL_PRED->davek,2),"@E 9,999,999.99")','transform(round(GL_PRED->prep,2),"@E 9,999,999.99")','transform(round(GL_PRED->skupaj,2),"@E 9,999,999.99")','transform(round(GL_PRED->ptt,2),"@E 9,999,999.99")','DATUM_PLA','VALUTA','KNJ','STATUS','transform(GL_PRED->PLACANO,"@E 9,999,999.99")','PRED','substr(GL_PRED->KON,2,1)', 'substr(naslovi->KOM2,46,1)' } ;Regards/Saludos,
radohabjan
Thanks Roberto for the help.
I knew, that this was not a bug, but my bad knowledge.
But now I can switch all browse with grid. I hope that this was the last problem.
Best regards Rado
Best regards Rado
