1st column justification in the grid
Czarny_Pijar
Post by Czarny_Pijar »
Working example and picture here viewtopic.php?f=15&t=1366 ;)
The first column in the grid is intended to be centered, alas remains left-aligned .
Re: 1st column justification in the grid
Czarny_Pijar wrote: The first column in the grid is intended to be centered, alas remains left-aligned .
Hi Czarny
HMG Reference wrote:- The leftmost column in a grid control must be left aligned.
Czarny_Pijar wrote:Working example and picture here viewtopic.php?f=15&t=1366 ;)
As Esgici said, this is clarified in the reference.
This is a limitation inherited from Windows ListView control.
The trick to workaround this, is to create a first column with 0 width. So, the first visible column will be the second, that could be aligned as you wish.
Hi Czarny,
Please take a look for the following interesting thread with a small trick:
viewtopic.php?f=5&t=1124#p7836
Hope that helps :idea:
Czarny_Pijar
Thank you all and sorry for the mess.
Next time before posting I will check at least the earlier posts for the existng solutions.
Hi Czarny,
Thanks for remember us that.
I'll must test and analyze the code yet to consider its inclusion in HMG.
gfilatov wrote:Please take a look for the following interesting thread with a small trick:
I've not tested, but I'm pretty sure that this hack is working fine.
The hack consist of adding an extra-column, when column zero is not left-aligned and later deleting the original one (the column #0).
   if( iColumn != s )
      ListView_DeleteColumn( hc, 0 );       // <-- this hack
The problem is that according Microsoft it can't be done :)
The following quote is from ListView_DeleteColumn macro documentation at msdn(http://msdn.microsoft.com/en-us/library ... S.85).aspx)
Column zero of the list-view control cannot be deleted.
Pretty strange... maybe I'm missing something...
