Wish for IDE
Wish for IDE
Hi
I have some wish for IDE :
- I eagerly want back the "Exclude Item" option of project menu.
By the way, "Delete Item" option delete form (.fmg) file from disk and work as "Exclude Item" for module (.prg) files.
IMHO deleting any file from disk should not be duty of IDE.
- Building main.prg and main.fmg by IDE may be dependent to confirmation (or a configuration option) of user, not automatic.
- Also, asking user confirmation at shutdown may be a configuration option.
- May be not easy, but I wish "multiple projects" feature for IDE (instead of having multiple copy parallel running).
With my best regards
- mustafa
Re: Wish for IDE
Hello friends:
A silly question, I think not all users of HMG
They use the full IDE, I for example, I use it a lot
for designing forms, but when I have to compile I
using Build.bat.
For this course I have to rename the File.Fmg to File.Prg
And add in the header # include "hmg.ch" Main Function
and modify the Windows Main Compile with Build.bat
My question is: In the IDE -> Project -> Save Form, also
Could interspersed? Save Form as Prg?
Do not know if it is very difficult but it would be nice to have the form
Prg directly.
A Greeting
Hola amigos:
Una pregunta tonta , creo que no todos los usuarios de HMG
Utilizan el IDE totalmente , yo por ejemplo , lo utilizo mucho
para diseñar formas, pero cuando tengo que compilar estoy
usando el Build.bat .
Para ello claro tengo que renombrar el Fichero.Fmg a Fichero.Prg
Y añadir en la Cabezera #include "hmg.ch" Function Main
y modificar el Windows Main para Compilar con Build.bat
Mi Pregunta es: En el IDE -> Proyecto -> Guardar Formulario, ademas
Podria intercalarse ? Guardar Formulario como Prg ?
No se si es muy dificil pero seria muy agradable tener el Formulario
directamente en Prg.
Un Saludo
using Build.bat.
Prg directly.
A Greeting
Hola amigos:
Un Saludo
Re: Wish for IDE
This would be a nice feature.Save Form as Prg?
Re: Wish for IDE
I agree - it would be GREAT feature.
Marek
Marek
- Czarny_Pijar
Re: Wish for IDE
I disagree.
As mentioned earlier viewtopic.php?f=5&t=1284, the programmers have different styles. I personally use only those less Profi. For me, the eradication of files FMG will mean a mess and confusion.
For those who have to correct manually the FMG files, I can write a batch file that :
- rename the extension of FMG to PRG
- add the necessary headers.
Please specify only the exact needs.
claudiotedesco
Re: Wish for IDE
Hola
Compilar con Build.bat es mas rapido que compilar con IDE?
Tengo un problema arme un formulario en un equipo Windows XP SP2 con 256 RAM, termine el formulario con varios controles y cuando lo compilo con IDE algunos controles no aparecen. Reinicio la PC y cargo nuevamente el proyecto y ahi si funciona correctamente.
Alguien sabe a que se debe?
Perdon por mi ingles
Gracias
Claudio
Hello
Compiling with Build.bat is faster to compile with IDE?
I have a problem assembling a form on a Windows XP SP2 with 256 RAM, complete the form with various controls and when you compile with IDE some controls do not appear. Reboot the PC and reload the project and there it works correctly.
Someone knows what is that?
Sorry for my English
Thanks
Claudio
Gracias
Claudio
Hello
Thanks
Claudio
Re: Wish for IDE
I agree with CzarnyCzarny_Pijar wrote:I disagree.
This is a working style of programming and IDE gives always generalized possibilities, without obligation of any specific way.
Regards, saludos.
Re: Wish for IDE
I do agree Esgici and Czarny.
IMHO, there shall be some option to find out the source code of a form definition inside IDE.
- HMG Founder
Re: Wish for IDE
claudiotedesco wrote:Hola
Gracias
Claudio
Hello
Thanks
Claudio
English:
Submit them to the bug report section according the following rules:
The bug report MUST include a DETAILED DESCRIPTION of the problem AND a simple
CODE SAMPLE (including all necessary files to get it run) showing it.
Besides that, you MUST indicate Windows and HMG versions used.
Español:
Por favor, enviarlos a la sección 'Bugs' del foro de acuerdo a las siguientes reglas:
El reporte DEBE incluir una DESCRIPCION DETALLADA del problema y un ejemplo simple que permita verificarlo incluyendo todos los archivos necesarios para poder compilarlo y ejecutarlo.
Además debe indicarse la versión de Windows y HMG utilizadas.
- mustafa
Re: Wish for IDE
Hello friends
In my humble opinion, I am not raising "IDE yes, IDE no" whether or not,
as I put in my Previous Post, I am unable to program with the IDE, I belong
to SUMMER'87 school and is very difficult to leave the old ways of working.
When I started with HMG ide wonder I lost the writing method
out of control because I ignored all the issue of controls and buttons.
Today still do not understand many things that contain the controls and the
Making Form control saves me much time to work, but of course I work
with the Prg and clear I have to copy and paste or rename the file FMG
For this I would like the IDE tubiera the option of recording in Prg.
Hola amigos
En mi humilde opinión , yo no planteo "IDE si o IDE no ", como puse en mi
anterior Post , yo soy incapaz de programar con el IDE , pertenezco a la
escuela de SUMMER'87 y es muy dificil dejar los antiguos métodos de trabajo.
Cuando empeze con HMG el ide me ha ido de maravilla para escribir el método
de cada control ya que yo desconocia todo el tema de controles y botones.
Hoy aun no entiendo muchas cosas que contienen los controles y al Hacer el
Form del control me ahorra mucho tiempo de trabajo, pero claro yo trabajo
con los Prg y claro tengo que copiar y pegar o renombrar el fichero FMG
Por esto me gustaria que el IDE tubiera la opcion de grabar en Prg.
Hola amigos
