Hello everyone.
I noticed something strange.
I made a transcoding program that reads data from a table and writes them to a new one.
The program has only one main form, from which you perform some tasks (in particular the problem occurs with "p006_A ()" the bigger table) and, for each record read, update a counter on the form.
Problem: if I move the mouse outside the form, the program seems to stop, actually continues to run.
The title bar, after a few minutes, shows "non risponde" (not responding). I repeat: the program continues to run.
The source table has a size of 7.772KB and 4.749KB new one, both containing 6,544 records.
(If it's exist and it's not only my problem!) For me, it's not a big problem because it is an operation to be performed only one time, but could be a problem for very long processes.
I attach the source( but since it contains some features that are part of a library that I wrote for me, you can not compile it) and an image.
I compile and run on M$ XP-SP3 (all update), HMG 3.0.27 (2010.03.27)
Best regards
program seems freezed
- NotRespond.zip
- (11.22 KiB) Downloaded 298 times
Luigi from Italy
www.L3W.it
www.L3W.it
Re: program seems freezed
Ciao Luigi, how are you ?l3whmg wrote: ...
I'd add a line ( DO EVENTS ) to your p003_B FUNCTION; I hope that this is the correct place (since your data files is missing, I can't test
This is a "magic" command that solve such problems, I hope will help to you too.
STATIC FUNCTION p003_B()
LOCAL nRecord := 0, nRecadd := 0, nRecupd := 0
LOCAL nX := 0
olddbf->(DBGOTOP())
DO WHILE !olddbf->(EOF())
nRecord += 1
IF l3w_fAddrec("tlanguag") == .T.
tlanguag->adminproc := "trasco01"
tlanguag->adminuser := l3w_fGetaini("usrlogin")
tlanguag->admintstp := HB_TTOS( HB_DATETIME() )
tlanguag->tlangcode := olddbf->tlangcode
tlanguag->tlangdesc := olddbf->tlangdesc
tlanguag->(DBCOMMIT())
nRecadd += 1
MSGSTOP("Impossibile aggiungere" + HB_OSNEWLINE() + "0" + olddbf->tlangcode)
DO EVENTS // <--------------------------------
olddbf->(DBSKIP(+1))
ENDDO
MSGSTOP("Finito" + HB_OSNEWLINE() + "Record Letti "+ STR(nRecord) + HB_OSNEWLINE() + "Record Aggiunti "+ STR(nRecadd) + HB_OSNEWLINE() + "Record Update "+ STR(nRecupd))
RETURN NIL--
Hi Esgici!!
Good, very good my friend and You?
Many thanks for your suggestion: you are very fast!
During your replay I've tested my program and I can add this note to my previous post: in any case the program it's freezed.
Any way I'll try your suggestion.
Best regards
Best regards
Luigi from Italy
www.L3W.it
www.L3W.it
- HMG Founder
I've not downloaded your sample, but I'll make a question:l3whmg wrote:Hello everyone.
Best regards
Had you used DO EVENTS command inside your process?
Hi my friends,
I've applied Esgici's suggestion and now my program works fine. It's still running while I'm writing this replay
Many thanks to everybody.
Best regards
Best regards
Luigi from Italy
www.L3W.it
www.L3W.it
