ado
ado
Hi
I compile C:\hmg\SAMPLES\ADORDD-1\demo.prg with createtable procedure and it works ok!, but when I
compile without this procedure and deleted all records from test2.mdb this error appear;
Date:10/15/08 Time: 10:38:50
Error BASE/1100 Argument error:
TRIM
Called from RTRIM(0)
Called from _BROWSEUPDATE(620)
Called from _BROWSEREFRESH(1108)
Called from _REFRESH(3452)
Called from _REFRESHDATACONTROLS(4186)
Called from _ACTIVATEWINDOW(4072)
Called from MAIN(37)
I use win XP Sp2 and HMG 2.6.6.
Have anybody an idea what is a problem?
Miras
TRIM
Miras
- HMG Founder
Re: ado
I've obtained the same error without modify the sample under Vista SP!.miras wrote:Hi
TRIM
Miras
I'll try to find the cause of the problem and fix it ASAP.
Thanks for the report.
- HMG Founder
Re: ado
Well... I've obtained errors with console samples bundled with Harbour 1.01 too.Roberto Lopez wrote: I've obtained the same error without modify the sample under Vista SP!.
So, I've replaced 'librddado.a' from Harbour 1.01 with the 1.00 version and all appears to work fine.
I've attached the library to this message.
- HMG Founder
Re: ado
Since I was not able to attach the file (I'm doing something wrongRoberto Lopez wrote:Well... I've obtained errors with console samples bundled with Harbour 1.01 too.Roberto Lopez wrote: I've obtained the same error without modify the sample under Vista SP!.
- HMG Founder
Re: ado
I'll tested the sample without modifications.miras wrote:I've replaced 'librddado.a' Harbour 1.00 version Intl.rev(9175),
but the same error still.
Miras
I'll do the modification to the sample you've done and re-test.
- HMG Founder
Re: ado
I've made a new test with ADORDD-1 sample:miras wrote:I've replaced 'librddado.a' Harbour 1.00 version Intl.rev(9175),
Miras
- HMG 2.6.7
- librddado.a (22186 bytes) from Harbour 1.0.0
- CreateTable() Procedure eliminated
- All records from 'test2.mdb' deleted using Access
There was no errors. Browse appears empty.
Am I forgot something ?
- HMG Founder
Re: ado
And 'adordd.ch' from Harbour 1.0.0 too.Roberto Lopez wrote: - HMG 2.6.7
- HMG Founder
Re: ado
Ok. Thanks for the report.miras wrote:Hi Roberto!
I tested with HMG 2.6.7 and 'librddado.a' (22186 bytes) from Harbour 1.0.0
and 'adordd.ch' and everything is ok!
Thank You very much.
Miras
